Front passenger storage compartment won't open! - 2014+ Jeep Cherokee Forums
post #1 of 17 (permalink) Old 01-21-2014, 07:15 AM Thread Starter
Hey guys, I'm new to posting here but I've been a long time lurker to this forum. So here's my question...
My front passenger seat storage compartment some how got stuck shut. I didn't slam it shut, nor did I do anything different that i've done the past dozen or so times prior.
I've tried slipping my hands underneath the seat and tried pulling it up, but it's as if it's locked shut. Is there some kind of locking mechanism that I overlooked?
somescreename04 is offline
post #2 of 17 (permalink) Old 01-21-2014, 07:42 AM
Welcome to JCC. I am not aware of any locking mechanism, although I wish there WAS one. It would make the space even better.
Is there something in the compartment that could be jammed or caught, preventing the lid to hinge up correctly?
post #3 of 17 (permalink) Old 01-21-2014, 07:53 AM Thread Starter
Thanks!
That's a possibility, I'll check on that later today. The other issue it might be is the leather strap that you use to pull the seat up with... I removed the strap from its "sleeve" so it could be tucked under the seat, instead of having it resting on the actual seat. I did this so it wouldn't be obvious that there was a storage compartment underneath.
Maybe that piece of leather is somehow stuck in the latch?
post #4 of 17 (permalink) Old 01-21-2014, 08:12 AM
Could be....if so and someone sat in the seat it may be jammed tight and need a real pull to get past the friction.
post #5 of 17 (permalink) Old 01-21-2014, 08:18 AM
davidevo50's Avatar
If you lay down the back rest you may get better acces to the edge of the "lid" to pry it open?
davidevo50 is offline
post #6 of 17 (permalink) Old 01-21-2014, 08:30 AM
clew's Avatar
The strap lifts the latch that locks it closed, that's your problem. Dont have a solution, but in the future, tuck the strap in the crease to hide it, dont remove.
clew is offline
post #7 of 17 (permalink) Old 01-21-2014, 08:33 AM
It could even be that there's a problem with the hinge.
I'd say if you can't get it open and tired just about everything you could, you might as well take it into the dealer.
jimmy is offline
post #8 of 17 (permalink) Old 01-21-2014, 10:32 AM
Get in the back seat and feel around underneath for the pull cord. There is a latching mechanism. Happened to me, and you'll need to pull up on the cord to get it open.
CDNTrailHawk is offline
post #9 of 17 (permalink) Old 01-21-2014, 06:22 PM
Ausgti's Avatar
How did you go? Any updates?
2014 Jeep Cherokee Trailhawk
- Options
3.2 V6, 9spd Auto, Anvil Clear Coat, Technology Package, Tow Group, Comfort and Convenience Group, Leather Interior Group, Dual Pane Sunroof, Hood Decal, 8.4A Uconnect with Navigation, 9 Speaker Amplified Sound system
Mods
Weather tech front mats
5000k LED Fogs
Interior LED conversion
LED Back Up Lights
1080p Dash Cam
Ordered 29th of November
Built 25th of January
Arrival 20th of February
Delivery 15th of March
Ausgti is offline
post #10 of 17 (permalink) Old 01-21-2014, 11:01 PM Thread Starter
Good news to report! The strap had worked its way under the actual compartment, and was hanging underneath the seat. I was able to feed it back up through the seat, and had someone pull the strap up to its normal position.
Note to others: DON'T remove the strap from its sleeve, especially when you have your off-duty handgun in the compartment.
Thanks for all the tips guys, I appreciate it.
Secret compartment... WJM Interior 15 04-13-2014 02:04 AM
Sky Slider Full Open Roof sfdxsm Cherokee Purchasing and Orders 7 01-18-2014 10:17 AM
Passenger Thoughts/peoples reactions jeepc The JCC Lounge 10 01-17-2014 02:31 PM
Passenger Seat - Possible Issue beergeek Interior 3 01-11-2014 10:48 AM
Order Banks Open Friday, August 9th Seguerski Cherokee Purchasing and Orders 3 08-08-2013 01:47 PM
