2016 Cherokee Water Leak - Page 3 - 2014+ Jeep Cherokee Forums
 22Likes
post #21 of 31 (permalink) Old 05-22-2017, 11:39 AM
Hi g_freeman,
We can check TSBs for you (if you haven't already made contact with the dealership). Just PM your VIN if you wanted us to check.
Kori
Jeep Social Care Specialist
Kori,
I tried to PM you, but Taptalk says that JeepCares has too many messages and can't accept any more.
Can you PM me with alternate contact details?
Thanks for the help.
Sent from my 831C using Tapatalk
g_freeman is offline
post #22 of 31 (permalink) Old 05-22-2017, 05:31 PM
Originally Posted by g_freeman View Post
Kori,
I just deleted a couple hundred messages Hopefully you can PM us now!
Kori
JeepCares is online now
post #23 of 31 (permalink) Old 05-22-2017, 05:57 PM
Kori,
I still get the "Full Mailbox" error. You must be very popular
post #24 of 31 (permalink) Old 05-22-2017, 07:26 PM
Kori
If you didn't get my message, we are working on fixing your inbox issue. Sorry.
Len1304 is online now
post #25 of 31 (permalink) Old 05-23-2017, 08:38 AM
Kori,
Hi g_freeman,
I just went in and deleted even more messages, try again! (3rd time is the charm )
@Len1304 thanks for looking into this for us!!
Andrea
post #26 of 31 (permalink) Old 05-25-2017, 10:24 PM
Local dealer said that the mud i drove through pushed the AC drain hose off the bulkhead fitting on the frame. I'm not sure that I believe them. I don't see any evidence of mud on the interior of the Jeep, even after removing all the interior trim. Instead, I think that the AC drain hose was not installed correctly at the factory or worked off in the winter.
Anyway, remove the trim panel in the passenger side foot-well on the center console. Check that the AC drain runs from the evaporator core to the bulkhead fitting on the transmission tunnel. If it has worked off, re-connect it.
Once that is done, you will need to dry out the carpet/padding. I've parked my Jeep outside and placed a space heater in the cabin. I also pulled the door jam trim so I could lift up the carpet and blow the warm air from the space heater into the padding. I'll run it over night with the windows open. My goal is to dry out the pad so that mold or rust won't grow.
I don't see a way to lift up the rear passenger carpet without removing the front passenger seat. Does anyone have any hints? The seat fasteners don't look like a hex or a torx head. What tool I need to buy?
post #27 of 31 (permalink) Old 05-25-2017, 10:41 PM
I don't know the tool you need but I remember a shop I went to last year needed to buy tools just to install gear into my Dart and they are the same bits.
post #28 of 31 (permalink) Old 05-25-2017, 11:04 PM
Hello.
I notice the water problem on the rear passenger area when I was going to vacuum the rear floor of my 2016 Jeep Cherokee Sport. My Jeep has some Goodyear carpets (very similar to the Weathertech ones) on top of the removable factory carpets. Long story short, there was water and lots of very nasty mold (and black, white, green) sandwiched between the goodyear carpets and the factory removable carpets.
I cleaned the whole thing but I'm worried about the issue, thinking that the water may come from the A/C. I guess I need to take another trip to the dealer to get that fixed.
Do anyone here has the same issue? What did you tell the dealership and how did they fixed the problem?
Thanks!
waltrodz is offline
post #29 of 31 (permalink) Old 05-26-2017, 12:25 PM
Originally Posted by waltrodz View Post
Hello.
Thanks!
Hi waltrodz,
We do have a technical service bulletin regarding leaks in the front passenger area. Since yours is the rear, it doesn't apply exactly, but may give the dealership something to go off of. That TSB is #23-015-16 REV. A.
Kori
post #30 of 31 (permalink) Old 05-29-2017, 01:25 AM
Xinarin13's Avatar
When it is time to rid yourself of the mold smell that will linger, i swear by the BioCide CLO2 Auto Shocker. Smells like a pool for a bit and when that smell wears off there is no smell left... just make sure you run the AC for at least 15 minutes. I left it for 24 hours and ran the ac (auto started it) once at the beginnig of the 24 and once at the end for 15 mins apiece. It saved our Ford when even pro detailers couldnt get the smell out.
Plus it is only 20 or $30 and has a money back guarantee.
https://www.amazon.com/gp/aw/d/B001H...rb_top?ie=UTF8
David_Baker and 04Freedom like this.
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
VIDEO: Water Fording in Jeep Cherokee humvee256 2014+ Jeep Cherokee General Discussion 27 03-21-2016 10:32 PM
2016 Jeep Cherokee vs. 2016 Subaru Forester: Which Is Better? PeteB Jeep Cherokee Reviews 30 01-20-2016 12:06 AM
2014 Cherokee Roof Leak - Front & Back KALive 2014+ Jeep Cherokee General Discussion 7 12-09-2015 06:40 PM
Water leak in cargo area Hobbes9112 Interior 13 06-18-2014 04:00 PM
Water leak on to exhaust?? Jonesy's Jeep Engine and Technical Discussion 6 06-06-2014 08:44 PM
