Air cabin filter - Page 2 - 2014+ Jeep Cherokee Forums
 6Likes
post #11 of 17 (permalink) Old 02-01-2017, 12:54 PM Thread Starter
Alfrik's Avatar
Actually there is a u-tube video on how to do it. Also on this forum there are detailed instructions on how to do it.
I did mine for the first time last year and still struggled a bit as there is a trick to doing it.
It just involves wiggling the cover under the glove box just enough to carefully pop the side cover panel off and remove it.
Just be careful with the clip holding the filter in as it will break if forced.
This time when I do it it will be 10 minutes or less to change it.
But just one word of caution: There is an air bag located around that glove box.
Also I picked up 2 filters through e-bay dirt cheap. They look identical to the OEM one.
I do plan on changing them 1x a year after I saw what the OEM one looked like after 2 years.
Yeah, I went and ordered trim tools after using a flat head screwdriver for my wife's 200. After just over a year it was filthy and full of German Shepherd.
Jeepster1 and Duke2015 like this.
Alfrik is online now
post #12 of 17 (permalink) Old 02-01-2017, 08:27 PM
Originally Posted by 40_over_S9 View Post
Has anyone tried the "Fresh Breeze" cabin air filter that contains carbon and baking soda (to help neutralize odors) -- and if so, does the specified type CF12000 fit well in the KL?
http://www.framfreshbreeze.com/faq.aspx
I've been using Mann carbon cabin air filters in my Jetta for several years, and they do absorb unpleasant exhaust fumes, etc. but still need to be replaced annually. I'd like to find a similar product for the Cherokee.
I have and fit perfect. i have notice no smells since installing in August.
Bright White
2.4L
Jan 2015 Build
Xenon Depot 4300k HID Upgrade
Upgraded to 8.4AN
OEM Hitch and Bezel
K&N CAI
scottb is offline
post #13 of 17 (permalink) Old 02-01-2017, 08:51 PM
I ordered mine off eBay and ordered two of them for like $9 shipped. Got it about 30days from China (in december and can see major shipping / custom delays) but once I received them I installed it and fit like a glove.
14 Cherokee Limited
"Blue orbs" are extremely calming and peaceful. This orb may be your spirit guide, offering you spiritual guidance and protection.
BlueOrbs is offline
post #14 of 17 (permalink) Old 02-14-2017, 10:55 AM Thread Starter
Alfrik's Avatar
Originally Posted by Thaiwoo View Post
Which one did you get? I ordered one from Ebay from China and it never showed up. Recently had a recall done and had them change the filter at the tune of $81 for part and labour :-(
I can't recall, but it was all of about $8 off Amazon.
post #15 of 17 (permalink) Old 02-14-2017, 11:13 AM
rumrunner's Avatar
this is the one I got
EcoGard XC10305 Cabin Air Filter $11.40
https://www.amazon.com/EcoGard-XC103...ype=automotive
shemmar360 and BumblebeeBeer like this.
rumrunner is offline
post #16 of 17 (permalink) Old 02-15-2017, 09:10 AM
Best solution to keep out bad smells is to change the filter at least 1x a year.
Once that air flow decreases through the heating/cooling system that is the start of potential issues.
Poor air flow increases humidity levels in the system. Add the darkness of the system and any organic material like dust/dirt in it and you now have a breading ground for mold.
You might actually begin to see it first if you are lucky on the filter material itself. If it gets into your system itself you may be looking at one large repair bill to rid it out of the vehicle.
Smells are a good indicator that things are not well in the heating cooling system. With good air flow mold can not grow. Thus keeping that filter clean provides good air flow.
There is mold all over, as it is part of the environment. The job is to just prevent if from active growth and keep it dormant.
Just a suggestion.
post #17 of 17 (permalink) Old 02-15-2017, 12:03 PM Thread Starter
Alfrik's Avatar
I'm pretty sure that's the one I got too.
Engine Air Filter + Cabin Filter... Are these up to OEM Spec? XtremeModder Engine and Technical Discussion 6 04-13-2016 06:27 PM
Engine Air Filter and cabin air filter replacement crozep Owners' Garage 10 04-10-2016 08:54 AM
When to change air and cabin filter? XtremeModder Engine and Technical Discussion 11 02-12-2016 08:16 AM
Cabin Air Filter Jerryh Owners' Garage 2 03-05-2015 03:00 PM
cabin air filter? usnret Engine and Technical Discussion 5 02-05-2014 02:06 PM
