Air cabin filter - 2014+ Jeep Cherokee Forums
 4Likes
post #1 of 17 (permalink) Old 01-29-2017, 04:42 PM Thread Starter
Alfrik's Avatar
Air cabin filter
I picked up two filters from Amazon, one for Hawkeye, and one for my Wife's 2016 200. Now to go get trim removal tools. I cursed far too much for a simple filter replacement getting that plastic trim rivet out.
Alfrik is offline
post #2 of 17 (permalink) Old 01-29-2017, 06:53 PM
jamie1's Avatar
What plastic rivet? Nothing has to come off, other than the side cover and it has 2 clips. You just give it a sharp pull and off it comes.
jamie1 is offline
post #3 of 17 (permalink) Old 01-29-2017, 07:38 PM
Which one did you get? I ordered one from Ebay from China and it never showed up. Recently had a recall done and had them change the filter at the tune of $81 for part and labour :-(
Thaiwoo is offline
post #4 of 17 (permalink) Old 01-30-2017, 12:11 PM
That seems extremely high for just the cabin air filter, the part should only be about 20-30 and labour would be only about 5 minutes, I would suggest that you speak to wherever you had the filter changed and question them on the cost.
2016 Jeep Cherokee Limited
True Blue w/ Black Leather
3.2L V6 w/ AD1, Luxury Group, Trailer Tow Group, Uconnect 8.4AN, 9 Amplified Speakers with Subwoofer
josh6025 is offline
post #5 of 17 (permalink) Old 01-30-2017, 12:53 PM
Woa, my dealer charged me 30 some dollars with tax for OEM and none for labor since they said it was a 5 minute job.
They didn't even want me to change it so early (I did at 15k ish) thinking it would be a waste of money. I told them that I drove through a lot of construction zones with lots of dust in the air. They took the filter out for inspection free of charge. They were surprised how dirty the filter already was.
aaridici is offline
post #6 of 17 (permalink) Old 01-30-2017, 07:26 PM
Originally Posted by josh6025 View Post
That seems extremely high for just the cabin air filter, the part should only be about 20-30 and labor would be only about 5 minutes, I would suggest that you speak to wherever you had the filter changed and question them on the cost.
It seems the dealer prices are all over. They quoted me $81. High but I wanted it done. Had an oil change done as well. At the end I had sticker shock and just wanted to get the heck out of there. On the way home I noticed they did not even reset oil life.....
Looking further at the bill I noticed they did the engine air filter as well even though that I did not ask for it and charged me $120 for the cabin filter exchange. When I called I was asked, "so you want a refund?" Heck yeah. So back I went.
@aaridici I assume your some $30's are US, fairly close to what paid for the filter here in Canada. Except you did not pay for installation.
Thaiwoo is offline
post #7 of 17 (permalink) Old 01-30-2017, 09:30 PM
40_over_S9's Avatar
Has anyone tried the "Fresh Breeze" cabin air filter that contains carbon and baking soda (to help neutralize odors) -- and if so, does the specified type CF12000 fit well in the KL?
http://www.framfreshbreeze.com/faq.aspx
I've been using Mann carbon cabin air filters in my Jetta for several years, and they do absorb unpleasant exhaust fumes, etc. but still need to be replaced annually. I'd like to find a similar product for the Cherokee.
2016 Jeep Cherokee Latitude (7/15 build)
AD1, 3.2L V6
Tow and Cold Weather groups, UConnect 8.4
Yaesu FT-857D HF/VHF/UHF Transceiver w/Little Tarheel HP "screwdriver" antenna
Icom ID-880H 2m/70cm D-Star/FM Transceiver w/Diamond SG7500A antenna
40_over_S9 is offline
post #8 of 17 (permalink) Old 01-30-2017, 10:07 PM
jeepfan4x4's Avatar
I know others on here have used it as well, but yes it fit good and was easy to install and a good quality filter.
40_over_S9 likes this.
jeepfan4x4 is online now
post #9 of 17 (permalink) Old 01-30-2017, 10:44 PM
When I had the engine air filter changed in my Patriot they charged me $30 for the part and they said they would do the cabin filter for $30 as well but I had already gotten a new filter for it; I was not charged any labour since it was already in having the oil change done.
josh6025 is offline
post #10 of 17 (permalink) Old 01-31-2017, 08:25 AM
Actually there is a u-tube video on how to do it. Also on this forum there are detailed instructions on how to do it.
I did mine for the first time last year and still struggled a bit as there is a trick to doing it.
It just involves wiggling the cover under the glove box just enough to carefully pop the side cover panel off and remove it.
Just be careful with the clip holding the filter in as it will break if forced.
This time when I do it it will be 10 minutes or less to change it.
But just one word of caution: There is an air bag located around that glove box.
Also I picked up 2 filters through e-bay dirt cheap. They look identical to the OEM one.
I do plan on changing them 1x a year after I saw what the OEM one looked like after 2 years.
Engine Air Filter + Cabin Filter... Are these up to OEM Spec? XtremeModder Engine and Technical Discussion 6 04-13-2016 06:27 PM
Engine Air Filter and cabin air filter replacement crozep Owners' Garage 10 04-10-2016 08:54 AM
When to change air and cabin filter? XtremeModder Engine and Technical Discussion 11 02-12-2016 08:16 AM
Cabin Air Filter Jerryh Owners' Garage 2 03-05-2015 03:00 PM
cabin air filter? usnret Engine and Technical Discussion 5 02-05-2014 02:06 PM
