Driver Side Door Sticks - 2014+ Jeep Cherokee Forums
 1Likes
  • 1 Post By SkipW
post #1 of 8 (permalink) Old 03-27-2017, 05:34 PM Thread Starter
Anyone have a fix or suggestion to help with a sticking Driver side door? I have a 2014, and the door has slowly been getting worse and worse as far as sticking goes. I basically have to shoulder it open at this point. I don't see any obvious signs of rubbing or scraping. Thanks!
shards397 is offline
post #2 of 8 (permalink) Old 03-27-2017, 09:44 PM
Although you don't see any obvious signs, it must be hitting somewhere...have you checked the hinges to see if top one is loose/bent? Maybe double check latch mechanism and lube? Also check all the weatherstrip and lubricate. Might as well try a bit of everything before a dealer check...
ptram likes this.
post #3 of 8 (permalink) Old 04-12-2017, 04:24 PM
PDXcherokee's Avatar
have the same problem myself. Would love to know how to fix this!
PDXcherokee is offline
post #4 of 8 (permalink) Old 04-12-2017, 04:28 PM
What do you mean by "sticks?"
Is it metal on metal?
Is the weatherstripping sticking to the door?
Does it make any sounds when it does open? (Creaking metal, peeling plastic, ripping, scratching?)
And, maybe most importantly...have you visited the dealership?
gravitywell is online now
post #5 of 8 (permalink) Old 04-13-2017, 02:41 PM
rumrunner's Avatar
clean & treat the weather stripping?
rumrunner is offline
post #6 of 8 (permalink) Old 04-14-2017, 12:34 PM Thread Starter
To answer a few questions, no noise and no visible signs of what is causing the issue. When watching from the outside, the sticking occurs before the door is open enough to see if weather stripping is stuck or some other place is sticking. Basically, once the stick/suction breaks, the door opens fine, but it is sealed shut until whatever it is gives up.
I thoroughly cleaned every point of contact I could find and then hit the weather stripping with some 303, and the problem is about 90% better. It still doesn't open 100% freely compared to the other doors, but I no longer have to literally put my shoulder into it to get it to open.
post #7 of 8 (permalink) Old 04-14-2017, 03:16 PM
rumrunner's Avatar
good news! just don't ever use Pam or similar cooking spray. I tried that one winter & had an awful time cleaning up the mess
post #8 of 8 (permalink) Old 04-22-2017, 04:08 PM
schira's Avatar
White lithium grease on the hinges
2016 Jeep Cherokee Trailhawk 3.2L Rhino
schira is offline
Driver side door rattle/creak dsdooper Interior 4 03-25-2017 06:49 PM
Passive Entry not unlocking the driver side door? homieBadger Electronics, Audio, and Lighting 11 12-29-2016 04:26 PM
Use Warranty on Driver Side Door. R2D2 Exterior 3 03-29-2016 12:57 PM
Moisture in Driver side LE Light Nielcoop Electronics, Audio, and Lighting 4 11-08-2015 10:51 PM
No power to visor light/garage door opener on driver's side LeCreaux Electronics, Audio, and Lighting 18 09-08-2015 04:17 PM
