Window/Door Locks Controls Loose - 2014+ Jeep Cherokee Forums
  • 1 Post By dhh3
  • 1 Post By Manitoulinman
post #1 of 6 (permalink) Old 05-15-2017, 11:25 AM Thread Starter
Hey everyone
I have a 2015 Cherokee and for some reason both of the window/door lock controls are loose and have movement back and fourth. When playing the stereo loud these both seem to rattle/vibrate quite a bit and the vibration rattle stops if I hold them firmly in place. Just wondering if there is a reason or way to tighten these or is it possible something came loose or broken off and I can buy new ones to replace? I attached a link to a video showing what I mean. Thanks guys!
https://youtu.be/iUHy-w6eKEM
UFC205 is offline
post #2 of 6 (permalink) Old 05-15-2017, 12:07 PM
They just pop out, straight up. Possibly either the front or rear retaining clip has broken off.
post #3 of 6 (permalink) Old 05-15-2017, 12:15 PM
BurtonRW's Avatar
It's normal, I think.
My window/door lock module has always had a little back and forth play - since taking delivery new - although mine has never rattled w/ the radio. I'm sure you could probably secure it with a drop of glue somewhere if you wanted to (not enough that it would be too hard to pop off later, of course), but I doubt anything is broken. Just extremely loose fit tolerances. -Rob
BurtonRW is offline
post #4 of 6 (permalink) Old 05-15-2017, 01:25 PM Thread Starter
Hey so I can just pull them straight up to remove no special tools or anything needed? Any special spot I should pull from? Thanks again for quick response much appreciated.
UFC205 is offline
post #5 of 6 (permalink) Old 05-15-2017, 01:54 PM
Thumbs up
Do you have a trim removal tool? If not, you can use a small flat blade screwdriver. Be careful not to damage it. Once the rear is loose, you can just pull it up. I just went out and did mine. All of one second! Chrysler has been using these switches for years, and they have to be unplugged to remove the inside door panels for speaker replacement! Once out, you might be able to build up the front or back with tape or similar to keep them from moving so far. Mine just moves a tiny bit.
Array likes this.
post #6 of 6 (permalink) Old 05-26-2017, 06:15 PM
Hi....I used a thin strip of double sided tape on the underside of mine....they just pop out and rifht back in..
Sent from my SM-G900W8 using Tapatalk
Manitoulinman is offline
Key Fob Door Locks with Horn Beeping mjm9731 2014+ Jeep Cherokee General Discussion 16 07-17-2016 12:40 PM
Drivers Side Door Unlock button now locks?? wpgguy Electronics, Audio, and Lighting 4 12-10-2015 12:27 PM
Outer Fuel Door Loose madchemist24 Exterior 16 09-23-2015 12:09 PM
Loose Parts & Creaky door while driving LeCreaux Interior 22 09-21-2015 08:29 PM
Interior door controls 'slide'? wooten 2014+ Jeep Cherokee General Discussion 7 06-28-2015 08:49 PM
