LED Fog and Headlight Installed (XenonDepot) - 2014+ Jeep Cherokee Forums
 305Likes
post #1 of 505 (permalink) Old 03-02-2015, 08:35 PM Thread Starter
DZOnline's Avatar
As the title says, this is a complete install of Xenon Depot's LEDs. They are brighter and a better color. This is an easy install and 100% plug and play. No errors, no issues, simple and impressed the two kits.
1) Remove wheel. Pretty much can't do this unless it's removed. Plus you get experience with the jack (not a big fan) and getting the wheel on and off.
2) Remove the 3 8mm bolts holding the wheel well lining.
3) Pull the plastic cover back. It might be helpful to remove the hex nut holding the cover at the bottom.
See step 3 here: http://www.blueox.com/Uploads/Docs/BX1136.pdf
4) Install the Fog and/or Headlights and spread out the aluminum cooling mesh.
Fogs just have retaining clips. Squeeze and pull.
Headlights have a cover. Twist about a quarter turn counter clockwise to remove. Then the lamp is removed by twisting counter clockwise as well. There are 3 tabs that hold it in place. I left the covers off the headlights, couldn't see another way to work the cable into the small area and reinstall the cover.
5) Enjoy!
Passenger is LED, driver is stock
Total time was less than 75 minutes.
Gotchas:
Passenger side is much more difficult, I suggest starting with the drivers side because you can see in the well a whole lot better. I did the passenger side first and struggled with the headlight.
The clips for the fogs are easy to remove, the headlights are much more difficult. Take your time and they'll come off eventually.
Getting the fog light to click in took a little finessing, squeeze the clips, they'll click.
The LEDs are removable from the cable. There is a threaded sleeve that needs to be tightened. I didn't find it useful to separate the two during the install. You can try of course.
Twist or zip ties might be useful, one for each lamp.
Final product:
PeteB, Adder, RojStock and 17 others like this.
My Overland Journey
Instagram
Facebook
DZOnline is offline
post #2 of 505 (permalink) Old 03-02-2015, 08:45 PM
Wow that looks great! In another thread I was told you couldn't do plug and play headlight replacement. How much was the whole set?
zander21510 is offline
post #3 of 505 (permalink) Old 03-02-2015, 08:49 PM Thread Starter
DZOnline's Avatar
They are about $135 for each set.
My Overland Journey
Instagram
Facebook
DZOnline is offline
post #4 of 505 (permalink) Old 03-02-2015, 08:50 PM
TheChadster's Avatar
That looks fantastic. What a great mod!
DZOnline likes this.
2015 Cherokee Limited | 4x4 | 3.2L | Bright White | Black Leather | Panoramic Moon Roof | Luxury Group | SafetyTec Group | Tow Package | 8.4A
Add-ons: Mopar Floor Liners | Interior LED Lighting | Stubby Antenna
TheChadster is offline
post #5 of 505 (permalink) Old 03-02-2015, 08:58 PM
Nicely done! Thanks for the writeup. Any way you could do a night time road shot? I'd be interested to see the distance and side lighting. Thanks.
UN4GTBL likes this.
post #6 of 505 (permalink) Old 03-02-2015, 09:04 PM
I gotta say one thing I've been disappointed by is the headlight output so I've been considering doing an HID or LED upgrade...any particular reason you went with LEDs vs HIDs or did you even consider HIDs?
UN4GTBL likes this.
post #7 of 505 (permalink) Old 03-02-2015, 09:11 PM Thread Starter
DZOnline's Avatar
@zander21510 Simply the plug and play part. HIDs seem to be more work, more parts and cost a bit more.
Going from 1000 lumens to 2500 for LEDs seem pretty great. HIDs are a bit more, but honestly the LEDs are amazingly bright.
flynn_lives and Duke2015 like this.
My Overland Journey
Instagram
Facebook
DZOnline is offline
post #8 of 505 (permalink) Old 03-02-2015, 09:20 PM
RojStock's Avatar
Look great and great write up as well @DZOnline.
I keep my eye out for your ride when driving around the Valley.
RojStock is offline
post #9 of 505 (permalink) Old 03-02-2015, 09:24 PM
flynn_lives's Avatar
Now I wish I would have gotten this instead of the HID kit, seems much easier to install.
2014 Cherokee Altitude 4x4
3.2L V6, Active Drive II
Off Road Suspension
Brilliant Black
Morocco Black interior
Cold Weather Pkg, Uconnect 8.4A, CD Player
AFE Cold Air Intake
XenonDepot HID Headlights & LED Foglights
flynn_lives is offline
post #10 of 505 (permalink) Old 03-02-2015, 09:38 PM Thread Starter
DZOnline's Avatar
I'm sold! I mean these LEDs are better than my Audi's Xenons. Just wish they turned with my wheel and I'd be in heaven. Very bright and a vast improvement from stock. I may have my driver fog a bit out of alignment. Will worry about it later.
Low beam:
Low + Fog
High
SkipW, mtudb24, PeteB and 10 others like this.
My Overland Journey
Instagram
Facebook
DZOnline is offline
Headlight/Fog Light LED Upgrade??? djack Electronics, Audio, and Lighting 22 05-12-2016 03:28 PM
LED Fog Lights Installed CDNTrailHawk Electronics, Audio, and Lighting 458 05-02-2016 08:51 PM
>>SALE: Savings on LED bulbs, LED Fogs, LED Dome Kits - Philips, Putco, XenonDepot<< XenonDepot XenonDepot 71 09-16-2015 05:14 PM
>> XenonDepot 30W CREE LED Fog Light / DRL Bulbs - SAVE BIG! << XenonDepot XenonDepot 8 09-04-2014 05:20 PM
Installed LED fog light on Letitude realcaptain Exterior 4 03-02-2014 10:06 AM
