Interior Bulbs (LED Replacement) - Page 3 - 2014+ Jeep Cherokee Forums
 133Likes
post #21 of 326 (permalink) Old 01-12-2014, 10:29 PM
Ok after a few hours with a multi-meter and some back of the envelope calculations. Here is what I have.
With the car running the line voltage is 13.6 volts.
I set up an adjustable power supply set to 13.6V and measured the Amperage of the stock bulb and my led's.
Stock:
V: 13.6
A: .4
Ohms: 34
Led's:
V: 13.6
A: .2
Ohms: 68
Using The formula for resistances in parallel and substituting to solve for r2 leaves the needed resistor size as 68 ohms with a dissipation of 2.72 watts. This should simulate a .4A load at 13.6 volts when the resistor is wired in parallel with the bulb.
AlexD is offline
post #22 of 326 (permalink) Old 01-13-2014, 12:49 AM
Ol'Greg's Avatar
Stock:
V: 13.6
A: .4
Ohms: 34
Led's:
V: 13.6
A: .2
Ohms: 68
How is that going generate the 1.21 "jigawatts" of electricity needed? A bolt of lightning is used to power the flux capacitor twice in the series, once with a large pole and hook rigged up to the car to help Marty get back to 1985..
Sorry couldn't resist..
AlexD, rt-texas and FlyinRob901 like this.
2014 Granite Crystal Metallic Trailhawk | 3.2L V6 24V VVT Pentastar| Tow Package | Hood Decal | Comfort/Convenience Group | Grand Canyon Brown Leather Interior | Uconnect 8.4AN with Navigation | 9 Speaker Amplified Sound w/Subwoofer | Dual-Pane Panoramic Sunroof | Black Powder Coated Wheels | •|||||||•
Ol'Greg is offline
post #23 of 326 (permalink) Old 01-13-2014, 01:01 PM
Can you make a video or pics of How did you open the covering for the interior lights. I tried to open if but it didn't opened
nikul.padhya is offline
post #24 of 326 (permalink) Old 01-13-2014, 02:31 PM
For the map lights and overhead lights the whole assembly separates from the roof liner. For the map lights find something flat and pry in between the assembly and roof liner on the side closest to the windshield first. The overhead light assembly comes apart the same way but the side facing the rear of the vehicle unlatches first. The reverse lights can be accessed via removing the access covers on the lift gates rear trim panel i used a jewelers screwdriver to remove the covers. The set of outboard reverse lights i believe you have to unbolt the light module. All of the other interior lights can be accessed by prying them out with a jewelers screw driver and depressing the plastic catch.
AlexD is offline
post #25 of 326 (permalink) Old 01-22-2014, 04:59 PM
Has anyone successfully replaced the (small) exterior bulbs with success? (No hyper flash and no lamp-out)
I'd love to do the plate lights and backup lights with cool white, and the front marker and front turn with amber.
Mine: '14 Latitude 4x4, White.
Options: Cold Weather, Comf & Conv, 8.4, Rmt CD.
MSRP: $30,775, Paid: $28,950 w/Nav enabled.
Also in the family:
Options: V6.
MSRP: $28,985, Paid $26,575
'15 Limited 4x4, White.
Options: Duel Pane roof, 8.4AN
MSRP $33,055, Paid $30,655
JeepRod is offline
post #26 of 326 (permalink) Old 01-22-2014, 05:37 PM
Wildturkey's Avatar
can you either send a link of these bulbs or actual bulb sizes thanks
Originally Posted by CDNTrailHawk View Post
Daylight, to its hart to see the lighting improvement, but:
I used these for the front map lights and cargo area side lighting (no issues):
And these for the rear dome lights (I had to splice in 2W 100Ω resistors in as shown to address some residual circuit power issues causing them to faintly glow when off):
Wildturkey is offline
post #27 of 326 (permalink) Old 01-22-2014, 05:44 PM
They're a standard T10 base wedge socket.
CDNTrailHawk is offline
post #28 of 326 (permalink) Old 01-22-2014, 05:52 PM Thread Starter
clew's Avatar
Another thing to note when purchasing there are 3 common types of SMD LED's youll come across: the 3528, the 5050 (roughly 3x the 3528), and the 5630 (roughly 1.5x the 5050, 4.5x the 3528)
I used a T10 5630 5-LED bulb and it is pretty bright...for me it was at the upper limit of what I would want up front, though I have considered a bigger array like CDNT's last picture or more for the cargo area
Anyone get their plate lights rigged up without a bulb out warning yet?
clew is offline
post #29 of 326 (permalink) Old 01-22-2014, 08:16 PM
I had a 10W resistor kicking around so I hooked it up to the plate light circuit. Did the trick!
post #30 of 326 (permalink) Old 01-22-2014, 08:21 PM Thread Starter
clew's Avatar
Nice. Threw out all my components from college a few years back and have been meaning to swing by radio shack to pick up some resistors. Good to hear that did the trick.
clew is offline
Interior Dimensions Jorf Interior 29 04-03-2014 05:44 PM
LED cupholders and accent lighting Spartan Electronics, Audio, and Lighting 18 02-26-2014 08:00 PM
Better Interior Photo... Xphyle Interior 18 11-17-2013 01:50 PM
Trail Carver Interior checkers 2014+ Jeep Cherokee General Discussion 8 11-12-2013 02:07 PM
2014 Jeep Cherokee Officially Unveiled as Liberty Replacement AutoGuide.com Jeep Cherokee News 4 08-29-2013 02:26 PM
