HID headlight installed without hot resistor - 2014+ Jeep Cherokee Forums
post #1 of 18 (permalink) Old 06-22-2015, 04:04 PM Thread Starter
I posted this update in my last post.
Start this new post just to share my experiment with other members to give you option if you hate to use hot resistor.
So the conclusion is that:
HOT Load resistor is not needed if you use the CANBUS HID Kit from DDM Tuning.
The theory with the load resistor is because the most HID kits use relay which only took a tiny fraction power of the original headlight circuit. This caused the detection circuit fault.
The DDM CANBUS dose not use relay. It power the HID bulb from the original headlight circuit. So the power draw is 35W rated. so no fault signal.
Based on the above theory, as an alternative, if you do not want to use the hot resistor as I , but you have a traditional HID kit. You can modify the tradition HID kit, connect the wire which was designed to battery back to the original headlight wiring with splitter (one to two splitter) and capacitor error corrector. (I did not do this experiment. This is just my guest based on above theory.)
Please try not to use hot resistor. Trust me. I am circuit designer in consumer electronic. It would kill your circuit or cause fire.
Hope this is useful to you members.
TonyJJJJ is offline
post #2 of 18 (permalink) Old 06-22-2015, 04:10 PM
ptrudel's Avatar
Do you mind posting some pics of your DDM's installed?
ptrudel is offline
post #3 of 18 (permalink) Old 06-22-2015, 04:43 PM
O|||||||O's Avatar
I'll keep an open mind here. As an electrical engineer and automotive test engineer for the past 35 years, explain to me the problems with using the resistors. Please be specific on where you see the problems.
eak likes this.
Aka "Krug"
2014 Mango Tango TH
Born on 4/14
Yes, it's been perfect so far
O|||||||O is online now
post #4 of 18 (permalink) Old 06-22-2015, 05:46 PM
^^ Agreed.
Only time it will cause a problem is if you use an underated wattage.
post #5 of 18 (permalink) Old 06-22-2015, 05:51 PM
EE/ME here too. Other than heat / reliability I see no issue... BUT if you can avoid wasting energy, why wouldn't you?
David_Baker likes this.
flaco is offline
post #6 of 18 (permalink) Old 06-22-2015, 05:58 PM Thread Starter
@O|||||||O
There is no problem to use resistor. It is just problematic to have a 290F (measured by others members before)hot resistor in the hot chassis. It add uncertainty and reliability issue, reduce life time of other electronics around it.
TonyJJJJ is offline
post #7 of 18 (permalink) Old 06-22-2015, 06:03 PM Thread Starter
Ha, find the link below to upload images. It is the picture to show the compare after I installed the first HID. On the left, the yellowish one is the original halogen.
TonyJJJJ is offline
post #8 of 18 (permalink) Old 06-22-2015, 07:59 PM
O|||||||O's Avatar
@O|||||||O
What other electronics? The resistors are inside the engine compartment where there is about 10,000-20,000 watts of waste heat being generated. I'm pretty sure my resistors are no running 290 deg. or my paint would be burnt off where they are mounted to the body for sinking heat.
Aka "Krug"
2014 Mango Tango TH
Born on 4/14
post #9 of 18 (permalink) Old 06-22-2015, 08:04 PM
O|||||||O's Avatar
This I agree with. If I could have done away with the resistors a year ago I would have. At the time the resistors were the only option. It ain't broke now so I'm just keeping the resistors and wait for LED's.
Aka "Krug"
2014 Mango Tango TH
Born on 4/14
post #10 of 18 (permalink) Old 06-23-2015, 01:49 AM
XtremeModder's Avatar
Haven't had any issues here either, had my XenonDepot Xtreme HID Kit w/ 6500K bulbs + resistors installed for about a month and a half now, work perfect every single time and haven't had the issue some have where one wont turn on unless you cycle them on/off a couple times... I'm not afraid of the resistors ruining anything as I had a professional do it and its on them...
XtremeModder is offline
LED Fog and Headlight Installed (XenonDepot) DZOnline Electronics, Audio, and Lighting 499 05-20-2017 12:23 AM
OEM HID Headlight swap with the halogen ones chinhaokoh Electronics, Audio, and Lighting 5 01-31-2015 09:15 PM
HID Resistor Mounting Location JCL2014 Electronics, Audio, and Lighting 6 01-30-2015 12:25 PM
Cherokee HID headlight mrboo007 Exterior 1 03-31-2014 05:18 PM
New Headlight bulbs and fogs installed (with pics) albnyblows Electronics, Audio, and Lighting 22 02-12-2014 09:02 PM
