Amplifier, Line out converter and sub woofer install - Page 3 - 2014+ Jeep Cherokee Forums
 21Likes
post #21 of 32 (permalink) Old 05-23-2016, 11:22 AM
AJU72's Avatar
Originally Posted by gduck24 View Post
Parts -
Line out converter amazon $20
Amp wiring kit $12
Whatever amp and sub you have - I have an old clarion 250, and a planet audio zetar 10". Both from my old vehicle, not made anymore.
directions:
pull off the AC control trim from the dash, pull strait out, top first.
remove 2 screws from bottom of silver trim/radio bezel. gently pull around the edges to get a finger in on the top side and them pull off. Key is just dont pull away to far in one spot.
Remove hazard connector and set aside
pull wire harness from back of screen.
Splice in wires on the LOC to harness. I actually installed a RAX jailbreak so I spliced into their side. I highly recommend the Rax and its good because you dont have to cut factory wires.
Wires go like this:
Red - continuous power
Black - ground
Gray /light green stripe - rear right
Gray /dark green stripe - rear right
Green /light green stripe - rear left
Green /yellow stripe- rear left
Attachment 71618
Attachment 71626
Pull power from battery to back of cab through main wiring harness, no pic. Dont actually go through the harness, just use a screwdriver or your hand if you can to go to the outside of the boot going through. If it leaves a little gap, just goob it up or tape over it. DONT GO THROUGH THE HARNESS BOOT! Route power through space behind radio, lots of room there.
Drop RCA, power and remote power wire from radio down and through the right side of the dash. Route wires to the back of cab through bottom door plate trim. You dont have to pull it all the way off, you can just pull up the inside edge and slide it in.
I just have the wires loose right now in the back. Still looking for a solid ground and trying to figure out if I am going to try to hide my amp. Right now it is tacked on the back of the amp. I may figure out a quick disconnect solution so I can pull this out if I need the room.
Build a box and install sub and amp.
Finish tucking wires, Mount gain control and put the trim back in and you are good to go!
Hey man I am planning on installing a sub and amp to my jeep. Was wondering about the wiring in the back of the radio. Which wires that go to the rear speakers are negative and which are positive?
AJU72 is offline
post #22 of 32 (permalink) Old 05-23-2016, 01:22 PM Thread Starter
gduck24's Avatar
Dunno. I just paid attention to that on my amp.
gduck24 is offline
post #23 of 32 (permalink) Old 07-29-2016, 11:35 PM
Can anyone help me, I have the premium sound system and I can't find any info on witch speaker wires to use to connect my mono amp, the 6 speaker systems seems to be different than mine.
Sparky9 is offline
post #24 of 32 (permalink) Old 11-10-2016, 12:38 PM
If you come across the information about your Trailhawk Iwould love to know the answers
Arial Firechilde
Arial Firechilde is offline
post #25 of 32 (permalink) Old 11-12-2016, 04:55 AM
dedelec's Avatar
Thumbs up
I hope this can help you!
Name:	SYSTEM WIRING DIAGRAMS 2 Jeep - Cherokee_Page_3.jpg
ID:	141473   Click image for larger version
Name:	SYSTEM WIRING DIAGRAMS 2 Jeep - Cherokee_Page_1.jpg
File Type: pdf SYSTEM WIRING DIAGRAMS 2 Jeep - Cherokee.pdf (346.6 KB, 284 views)
dedelec is offline
post #26 of 32 (permalink) Old 11-12-2016, 04:54 PM
dedelec, wondering how you got electrical wiring diagrams???
Last year we had access to https://techauthorityonlinedemo.extr...ew/classic.htm, but it was taken away.
post #27 of 32 (permalink) Old 11-12-2016, 10:49 PM
dedelec's Avatar
I bought the online manual for 19.95, it's quite complete! If you need any information, feel free to ask!
dedelec is offline
post #28 of 32 (permalink) Old 11-13-2016, 01:04 AM
Can you provide more detail on what and where you bought this online manual? $20 is an very good deal.
post #29 of 32 (permalink) Old 11-13-2016, 06:53 AM
dedelec's Avatar
Sure , you can buy it at this address: https://qualityservicemanual.com/361...service-manual
I paid with Paypal and it was an instant download, it took about 1-2 minutes and i had the pdf. version and it seems complete from wath i could check. I hope that is what you were looking for!
Array likes this.
dedelec is offline
post #30 of 32 (permalink) Old 11-13-2016, 12:55 PM
Thank you very much.
Help with installing a Line Out Converter(LOC) in a 2014 Kuraiholy Electronics, Audio, and Lighting 22 08-07-2015 02:56 PM
2015 line out converter gduck24 Electronics, Audio, and Lighting 1 06-22-2015 09:03 AM
9 Speaker Amplifier (Amp) Location mgp141 2014+ Jeep Cherokee General Discussion 2 02-13-2015 05:03 PM
9 Speaker Amplifier (Amp) Location mgp141 Electronics, Audio, and Lighting 0 02-12-2015 10:16 PM
Amplifier Power Wire Guage Specs. jim_87 Electronics, Audio, and Lighting 0 02-10-2015 12:00 PM
