Amplifier, Line out converter and sub woofer install - 2014+ Jeep Cherokee Forums
 23Likes
post #1 of 40 (permalink) Old 06-22-2015, 05:03 PM Thread Starter
gduck24's Avatar
Parts -
Line out converter amazon $20 Line out converter amazon $20
Amp wiring kit $12 Amp wiring kit $12
Whatever amp and sub you have - I have an old clarion 250, and a planet audio zetar 10". Both from my old vehicle, not made anymore.
directions:
pull off the AC control trim from the dash, pull strait out, top first.
remove 2 screws from bottom of silver trim/radio bezel. gently pull around the edges to get a finger in on the top side and them pull off. Key is just dont pull away to far in one spot.
Remove hazard connector and set aside
pull wire harness from back of screen.
Splice in wires on the LOC to harness. I actually installed a RAX jailbreak so I spliced into their side. I highly recommend the Rax and its good because you dont have to cut factory wires.
Wires go like this:
Red - continuous power
Black - ground
Gray /light green stripe - rear right
Gray /dark green stripe - rear right
Green /light green stripe - rear left
Green /yellow stripe- rear left
Pull power from battery to back of cab through main wiring harness, no pic. Dont actually go through the harness, just use a screwdriver or your hand if you can to go to the outside of the boot going through. If it leaves a little gap, just goob it up or tape over it. DONT GO THROUGH THE HARNESS BOOT! Route power through space behind radio, lots of room there.
Drop RCA, power and remote power wire from radio down and through the right side of the dash. Route wires to the back of cab through bottom door plate trim. You dont have to pull it all the way off, you can just pull up the inside edge and slide it in.
I just have the wires loose right now in the back. Still looking for a solid ground and trying to figure out if I am going to try to hide my amp. Right now it is tacked on the back of the amp. I may figure out a quick disconnect solution so I can pull this out if I need the room.
Build a box and install sub and amp.
Finish tucking wires, Mount gain control and put the trim back in and you are good to go!
gduck24 is offline
post #2 of 40 (permalink) Old 06-22-2015, 07:09 PM
citation10337's Avatar
Great location for that gain knob !
gduck24, SonicSoundKL and iBypass like this.
Limited ADII 3.2V6
Granite Crystal / Black
Luxury Package
Trailer Tow Package
Sunroof
10 Speaker sound
Navigation < with AUX Noise > Thanks Jeep
LED Running Lights
LED Interior lights
5% Tint
CQuartz UK < Best mod by far !
FlyBy30
citation10337 is offline
post #3 of 40 (permalink) Old 06-24-2015, 08:23 AM
Steak House's Avatar
+1
Nice Writeup - Thanks
gduck24 likes this.
Steak House is offline
post #4 of 40 (permalink) Old 07-02-2015, 11:58 AM
thebigler's Avatar
This should be a sticky +1
gduck24 and Jpollard86 like this.
ROLL TIDE
thebigler is offline
post #5 of 40 (permalink) Old 07-02-2015, 12:32 PM
Great write-up. I sold my Rockford P1 and amp recently. Just took up entirely too much space in the trunk.
gduck24 and Duke2015 like this.
post #6 of 40 (permalink) Old 07-05-2015, 05:38 PM
Nice. I wanted to upgrade my 6 speaker system but but was wondering about the amp turn on lead. Nice write up.
gduck24 likes this.
2015 Jeep Cheokee Sport
Billet Silver
Uconnect 5.0
tdfields988 is offline
post #7 of 40 (permalink) Old 07-07-2015, 12:03 AM Thread Starter
gduck24's Avatar
The LOC with the remote output makes the setup easy. 1 10" speaker really balances out the stock speakers well. As a former audiophile, it could use more highs, and an amp on mids for more punch, but I am really pleased. The gain knob is a must too. The system really varies on bass across the inputs. Sat is muddy, radio has way to much bass, and SD and Bluetooth are about normal.
I'm going to do a video on the tax jailbreak. It's worth every penny.
Sent from my A0001 using Tapatalk
gduck24 is offline
post #8 of 40 (permalink) Old 07-07-2015, 12:04 AM Thread Starter
gduck24's Avatar
I plan on doing a quick connect setup soon so I can remove the box easily. I'll post on it when I do.
gravitywell likes this.
gduck24 is offline
post #9 of 40 (permalink) Old 08-07-2015, 02:00 PM
thebigler's Avatar
For some reason I do not see these same color wires? I have a 2014 trailhawk. can someone point me in the right direction?
*also I have the nine speaker premium package
ROLL TIDE
post #10 of 40 (permalink) Old 08-07-2015, 03:21 PM
daytona125's Avatar
Thank you for your contribution. Looks great!
gduck24 likes this.
daytona125 is offline
Help with installing a Line Out Converter(LOC) in a 2014 Kuraiholy Electronics, Audio, and Lighting 22 08-07-2015 02:56 PM
2015 line out converter gduck24 Electronics, Audio, and Lighting 1 06-22-2015 09:03 AM
9 Speaker Amplifier (Amp) Location mgp141 2014+ Jeep Cherokee General Discussion 2 02-13-2015 05:03 PM
9 Speaker Amplifier (Amp) Location mgp141 Electronics, Audio, and Lighting 0 02-12-2015 10:16 PM
Amplifier Power Wire Guage Specs. jim_87 Electronics, Audio, and Lighting 0 02-10-2015 12:00 PM
