XenonDepot HID kit installation guide - Page 3 - 2014+ Jeep Cherokee Forums
 15Likes
post #21 of 52 (permalink) Old 07-24-2016, 08:03 PM
Originally Posted by Tmugz88 View Post
That's great to hear , I'll have to set some money aside for a set of these now that I know there is little to no issues .
Are the kits specific for our vehicles or do I need to purchase anything specifically with them? I've always ordered from DDM so this company is new to me.
Tmugz
Just put in the vehicle info and you'll get the kit for our vehicles.
Sent from my XT1254 using Tapatalk
DNTrailHawk is offline
post #22 of 52 (permalink) Old 07-25-2016, 08:44 AM
JeepCherokeeClub.com Vendor
XenonDepot's Avatar
@Tmugz88 - This is the 2015 Jeep Cherokee V-SPEC HID kit -- comes with everything you need.
Steve
Tmugz88 likes this.
Use our Shop by Vehicle tool to find the right lighting for your Jeep Cherokee, and the most up-to-date Cherokee lamp replacement guide!
1-877-522-2701 | info@xenondepot.com
XenonDepot is offline
post #23 of 52 (permalink) Old 07-26-2016, 01:00 AM
Tmugz88's Avatar
Thanks a lot Steve
XenonDepot likes this.
Replaced
Tmugz88 is offline
post #24 of 52 (permalink) Old 07-26-2016, 08:46 AM
XenonDepot's Avatar
No problem at all.
Steve
post #25 of 52 (permalink) Old 09-24-2016, 02:03 PM
just got the xtreme hid with pwm and led fog light kit for my 2016. the fog light no problem just plug and play. the hid not so easy. after 30+ time switching swapping sides and on and off the engine the light only came on two times with no error low light out massage. even took off the connector and plug it all the way to the car wire still wont fire.... try to call xenondepot but they close on sat and sunday. sighhhhh
anyone got any suggestion? i never experience any issus like this before.
stanc52 is offline
post #26 of 52 (permalink) Old 09-24-2016, 02:48 PM
Ribbertw's Avatar
Can't say I ran into any issues like this when I installed mine. Are both sides reacting the same way?
Do you have a voltage tester can verify that the right voltages are coming from the source (original plug) and to the new light where it plugs in? Btw, before you do that check what hids run for voltage. If you hook it up to a 12v light nothing good will happen (read boom)
Ribbertw is offline
post #27 of 52 (permalink) Old 09-24-2016, 05:33 PM
hi
i only try the driver side but with both hid bulb/pmw and wire. still no luck . and i dont have a voltage tester. steve told me is easy plug and play. too bad it didnt turn out that way
stanc52 is offline
post #28 of 52 (permalink) Old 09-24-2016, 06:19 PM
hi
Did you reverse the polarity on the wire harness side?
Caestus75 is offline
post #29 of 52 (permalink) Old 09-24-2016, 06:29 PM
Ribbertw's Avatar
It really was straight forward plug and play when I installed it.
But wait? Did you say you've only installed the drivers side??
I sort of thought they only worked properly in pairs??
Maybe get the passengers side installed as well
Ribbertw is offline
post #30 of 52 (permalink) Old 09-24-2016, 07:03 PM
i only try pass side. and i didnt know anything about about hooking up both side at the sane time then it might work. in my mind if one side didnt wanna light up. i swap bulb and the hid kit around to see if the other set work.. but unfortunately it didnt. unplug and reconnect many times and the light turn on one or two times ,once i turn the car off then it wont turn on again. to me its seem to be the connector problems.
sorry for my bad english. i guess i just wait until monday call them and see wasup.������
stanc52 is offline
Help, hid installation cbsan121909 Electronics, Audio, and Lighting 21 12-19-2016 10:27 AM
XenonDepot 6500K Kit installed. XtremeModder Electronics, Audio, and Lighting 42 09-26-2015 09:50 AM
KBCarStuff XenonDepot LED Conversion Kit ellF Cherokee (KL) Parts & Accessories 6 07-01-2015 08:30 PM
FOR SALE
XenonDepot LED headlight kit w/resistors
zander21510 Cherokee (KL) Parts & Accessories 5 06-19-2015 10:32 AM
HID installation TonyJJJJ Electronics, Audio, and Lighting 2 06-12-2015 02:32 PM
