High Beam Wire Tap - 2014+ Jeep Cherokee Forums
 11Likes
post #1 of 33 (permalink) Old 12-29-2015, 04:30 PM Thread Starter
V1N2E7T's Avatar
High Beam Wire Tap
I'm in the process of installing off road lights to my TH and want them to be triggered with the high beams, I have a relay and currently am trying to figure out which wire will act as a switch, preferably on the drivers side. Any help asap is welcome.
Thank you
2014 Jeep Cherokee Trailhawk Anvil
3.2L V6
Stealth Gobi Rack w/ ladder
Roof Rack Lighting
Noise Dampening above headliner
Aftermarket Backup Camera
Pastidiped Rims
Aussie lift
LED headlights and Fog lights
V1N2E7T is offline
post #2 of 33 (permalink) Old 12-29-2015, 04:51 PM
Wisconsin Mike's Avatar
The green connector plugged into the back of the headlight housing has 3 wires in it. One is common, one is to illuminate the headlight, and one is to toggle the high beam solenoid. It's that high beam solenoid wire you're looking for.
Unfortunately, I don't know where it goes from there.
UN4GTBL likes this.
Wisconsin Mike is offline
post #3 of 33 (permalink) Old 01-16-2016, 09:10 PM
Wondering if anyone has located a place to tap into the high beam solenoid actuator circuit. Looking to do the same (relay to turn on lighting with high beams)
post #4 of 33 (permalink) Old 01-16-2016, 09:56 PM Thread Starter
V1N2E7T's Avatar
I ended up finding the green connector behind the headlight, and it had three wires attached to it. There was a black, a white with blue stripe, and also a white with green stripe. The black is (obviously) the ground for both. The white with blue stripe is for the low beam. And the white with green line is the high beam.
(All on the drivers side)
I cut open the tubing a few inches away from the green connector and used a wire tap clip to connect a wire to it.
Now I don't have the wiring diagram I made on me but I used a 20amp inline fuse, a standard 40 amp relay, and I also used a project box with a master switch in case I ever wanted to disable my off road lights if someone else was driving.
The setup I have works exactly how I planned it to, immediately with the high beam switch, and off when on low beams or when master switch is off.
UN4GTBL, SkipW and Duke2015 like this.
V1N2E7T is offline
post #5 of 33 (permalink) Old 01-16-2016, 11:17 PM
Perfect, thanks!
post #6 of 33 (permalink) Old 01-17-2016, 02:53 PM
dougieshep12's Avatar
Any issues with the computer while the high beams are on? I'm thinking about the same thing for my lights.
2015 Trailhawk
dougieshep12 is offline
post #7 of 33 (permalink) Old 01-17-2016, 02:59 PM Thread Starter
V1N2E7T's Avatar
With my wiring set up only using the headlight wire as a trigger for the new relay i added there should be no additional power draw from the headlight. That being said i would not be able to test this fully as I have added the Xenon Depot LED headlight and foglight kit, so i already have headlight resistors installed.
3.2L V6
Roof Rack Lighting
Pastidiped Rims
Aussie lift
V1N2E7T is offline
post #8 of 33 (permalink) Old 01-17-2016, 03:29 PM
Thanks, I have a relay setup on my switch as well. You've given me enough confidence to give it a shot.
2015 Trailhawk
post #9 of 33 (permalink) Old 01-17-2016, 07:25 PM
Yep exactly the same as what I did and no probs at all.
Sent from a tiny mobile device with fat thumbs...
post #10 of 33 (permalink) Old 01-22-2016, 10:55 PM
E36Meerkat's Avatar
Any pictures would be super handy if you have a few spare minutes
Thanks!
E36Meerkat is offline
High beam circuit ? Mark_ Electronics, Audio, and Lighting 10 07-05-2015 05:06 PM
High Beam Uograde graniteman Electronics, Audio, and Lighting 22 01-07-2015 03:09 PM
Auto High Beam and Park Assist Questions... Aussie Electronics, Audio, and Lighting 12 08-13-2014 11:20 PM
Low/High Beam noise? sounbwoy Electronics, Audio, and Lighting 4 05-30-2014 10:38 PM
Are you using Automatic High Beam Headlamp function? YosemiteTrailhawk Electronics, Audio, and Lighting 9 01-18-2014 05:37 PM
