Tested LED License Plate Resistors. - Page 3 - 2014+ Jeep Cherokee Forums
 15Likes
post #21 of 42 (permalink) Old 01-21-2016, 07:43 PM
Duke2015's Avatar
victory! finally no more rear light our warning! got a pair of resistors for five bucks, the leds were a buck, two day shipping from amazon.
installation is so easy, the resistor plugs into the socket and led and that's it
Duke2015 is offline
post #22 of 42 (permalink) Old 01-21-2016, 07:47 PM
Duke2015's Avatar
i used big fat turn signal leds, then just switched the casing with a t10 bulb, way brighter than regular small t10s
Duke2015 is offline
post #23 of 42 (permalink) Old 01-21-2016, 07:50 PM Thread Starter
What resistance are those?
Do you have ESS? Do you get any errors, at all?
At Startup? At ESS turning the engine off, at ESS turning it back on?
And, do you have a link to what all you used?
post #24 of 42 (permalink) Old 01-21-2016, 08:00 PM
Duke2015's Avatar
2015 sport no ess
Amazon Amazon
here are the resistors, they didn't work when i used cheap leds
Amazon Amazon
so i just pulled off the casing off those cheap leds and switched em with bigger leds from
Amazon Amazon
anyways thanks for the tip about the plug-and-play resistors, they totally work
gravitywell likes this.
Duke2015 is offline
post #25 of 42 (permalink) Old 01-21-2016, 08:51 PM
Yes in these calculations we have to remeber that an incandescent globes resistance increases as it heats up. Ie, the higher the voltage, the brighter the light, the higher the resistance. The lower the voltage, the dimmer and cooler the light and the higher the resistance. Trying to calculate this is nigh impossible given all the variables of the lamp construction so testing current draw at around vehicle starting voltages is about the only way. This means we will actually end up drawing more current at running voltage as our replacement resistor will have to be lower causing a higher current drain.
The only other way would be to use a non linear resistor in the cavity behind the mount - ie use the globe as the load resistor in the cavity behind the light mount...
Sent from a tiny mobile device with fat thumbs...
post #26 of 42 (permalink) Old 01-24-2016, 09:36 PM
Duke2015's Avatar
i also did another mod; my leds were too bright, they lit up the whole back area, the whole bumper and the ground around it, so using duct tape i taped up most of the clear plastic cover only leaving a gap so the light would shine directly down only over the plate, i think it looks really cool, the rest of the sides around the plate and bumper are completely in the dark
Duke2015 is offline
post #27 of 42 (permalink) Old 01-29-2016, 03:28 AM
Treaty's Avatar
I installed those exact same resistors on my license plate bulbs this week, super easy, no more build out errors on startup. Question for you though, did you do anything special with the fitment? The OEM bulb plug fits into the housing tightly with a twist and that nice rubber O ring. The cheap rubber sleeve on the resistor lead that the bulb fits into doesn't fit tightly into the housing at all Though. I just poked mine in there and put the housing back in the tailgate and it seems fine for now... Wondering if you attached yours any differently though? (I was thinking about at least slapping some electrical tape over it to hold the bulb in the housing a little better).
____________________________
2014 Granite V6 Trailhawk
[Comfort/Convenience | Sunroof | 8.4AN w/ Nav | 9 Speaker]
Treaty is offline
post #28 of 42 (permalink) Old 01-29-2016, 05:05 AM
Duke2015's Avatar
glad it worked for ya, what led bulbs did you use?
i did the same as you, it just hangs in the housing, tape would be a good idea to hold it security
Duke2015 is offline
post #29 of 42 (permalink) Old 01-29-2016, 03:44 PM
Treaty's Avatar
I don't even remember which bulb I got. I just ordered a kit off of ebay. They look pretty similar to yours, but they have one less row of the LED's on them. the two for the license plate were supposed to be "can bus no error" bulbs, but they look like all the rest and never worked.
If I come up with a better idea than the electrical tape, I'll let you know
Treaty is offline
post #30 of 42 (permalink) Old 02-01-2016, 12:59 AM Thread Starter
Do either of you have ESS?
Installing resistors for License Plate Light Out error? Dundas Electronics, Audio, and Lighting 114 04-02-2017 04:53 AM
Led reverse and license plate lights hehateme2812 Diode Dynamics 5 04-05-2016 03:09 PM
LED License plate light vasH Electronics, Audio, and Lighting 15 01-23-2016 05:09 PM
Installed LED License Plate Light Dino Electronics, Audio, and Lighting 0 12-28-2015 07:59 PM
License plate LED ern3 Electronics, Audio, and Lighting 6 09-23-2014 02:06 AM
