Tested LED License Plate Resistors. - 2014+ Jeep Cherokee Forums
 15Likes
post #1 of 42 (permalink) Old 01-12-2016, 01:40 PM Thread Starter
Hey guys.
A few months back, I installed some interior LEDs and also changed out the Reverse and License plate lights.
I of course had error messages, one at start up for the license plates, and one when I put it in reverse for those corresponding lights.
I dealth with it for a little while, and decided to experiment a little bit.
I picked up some 194 resistors from Amazon (two of them.)
I had read previously that we only needed one per circuit. I tried the resistor on the left, and immediately had an error on start up. I then moved the resistor to the right, and immediately had an error on start up.
I shrugged, and installed resistors on both license plate lights. I turned the Cherokee on, and no errors!
Everything was good for about two weeks. Now, when ESS turns the engine back on, the License Plate Light error shows up. To me, this is more annoying than just reading it once when the Cherokee comes on.
Total, they cost me $15. So, I'm not really out anything. I'm unsure if I'm going to try other resistors, or just deal with the error.
post #2 of 42 (permalink) Old 01-12-2016, 01:41 PM
ptrudel's Avatar
What a pain in the rear...With the amount of LED lighting we have from factory, why not go LED across the board and be done with it.
gravitywell and FlyinRob901 like this.
ptrudel is offline
post #3 of 42 (permalink) Old 01-12-2016, 03:38 PM Thread Starter
Exactly. I was excited that it was potentially working. I may move them to the reverse lights to see if they help there.
I thought this info would help the other members with LED's and errors.
post #4 of 42 (permalink) Old 01-13-2016, 03:26 PM
Do you get an error on startup using both resistors? Other members on this forum had error messages after a few days. How is your first start up doing?
Perhaps this would be a good solution for those of us without ESS
2014 Limited, Billet Silver, V6, 4x4, Active Drive II, Luxury Group, Sunroof, Navigation
Mods: OEM skid plates, shark fin antenna, LED fogs, black KMC wheels with A/T tires and full-size spare, OEM trailer hitch, WeatherTech floor mats, Yakima Load Warrior w/ 40" LED Light Bar attached at the front and 2x 7" LED Light bars attached to the sides, using Thule aeroblade edge cross bars
cherokee is offline
post #5 of 42 (permalink) Old 01-13-2016, 03:52 PM Thread Starter
I'm two weeks in, and still zero errors at start up. The only errors I'm getting are occasionally with ESS.
If someone doesn't have ESS, this should be the thing for them.
post #6 of 42 (permalink) Old 01-13-2016, 08:05 PM
Will you be kind to give the amazon page for this resistor. thanks
justforfun is offline
post #7 of 42 (permalink) Old 01-13-2016, 08:29 PM
Dino's Avatar
Added this small license plate lightbar and tapped it into the platelights. No error lights or messages since installing.
ID:	102185   Click image for larger version
Black Plasti Dip Wheels - LED Interior Lights - LED Headlights - WeatherTech Floor/ Cargo - Mounted 15" Cree LED Light Bar -Trail-Hawk JeepLogo, Altitude 4x4,Altitude side Cherokee Decal, Rear Jeep Altitude Jeep Logo - Altitude Glossy Black Grill Added
On Order - Vinyl TH Decal for Hood (Matte Black non TH logo) - BlackHawk Badge.
In-process - Covering window Chrome w/ Carbon fiber Vinyl - Adding 4 round White LEDs behind grill.
Jeep Latitude 4x4 * 2.4 Tigershark * Cold Weather Group
Dino is offline
post #8 of 42 (permalink) Old 01-13-2016, 08:38 PM
Duke2015's Avatar
can u give us a step by step on how to tap the lights? the no error thing would be a life saver
Duke2015 is offline
post #9 of 42 (permalink) Old 01-13-2016, 09:43 PM Thread Starter
ProFocos T10 Warning Canceler Error Free Adapter LED Light Bulb Lamp Direct replacement for Wedge Type W5W 147 152 158 159 161 168 184 192 193 194 2825 https://www.amazon.com/dp/B00CVYU01C..._oSWLwbYMMYC81
post #10 of 42 (permalink) Old 01-13-2016, 09:52 PM
Dino's Avatar
The mini license plate light came with ground wire and hot wire and it had a built in resistor. Ran the wiring through the existing light bulb aera and tapped into one of the lights. Both bulbs still work but the bar puts out so much light you won't be able to tell. All and all took about 30 to 45 mins.
Dino is offline
Installing resistors for License Plate Light Out error? Dundas Electronics, Audio, and Lighting 114 04-02-2017 04:53 AM
Led reverse and license plate lights hehateme2812 Diode Dynamics 5 04-05-2016 03:09 PM
LED License plate light vasH Electronics, Audio, and Lighting 15 01-23-2016 05:09 PM
Installed LED License Plate Light Dino Electronics, Audio, and Lighting 0 12-28-2015 07:59 PM
License plate LED ern3 Electronics, Audio, and Lighting 6 09-23-2014 02:06 AM
