2014+ Jeep Cherokee HID kit - No Resistors - Plug+Play - Page 11 - 2014+ Jeep Cherokee Forums
 389Likes
post #101 of 625 (permalink) Old 03-19-2016, 02:02 PM
Ordered this today. Hopefully the weather will be good for the install.
Ben58 is offline
post #102 of 625 (permalink) Old 03-19-2016, 02:09 PM
imthatguy's Avatar
Got mine installed at lunch time. No EVIC's at all. I tried every combination to make it throw an error. Lights on, Auto on, Lights off then on again, nothing. Rock solid. Very pleased. When it's dark, I'll add a couple pics.
Thanks Steve & Xenon Depot for making this excellent product. Now, if anybody wants a set of LED's...
SkipW likes this.
Normally, my trucks are 1/10th the size.
2015 Bright White Trailhawk - All the junk in the trunk.
imthatguy is offline
post #103 of 625 (permalink) Old 03-19-2016, 02:24 PM
Polestar's Avatar
Installing mine right now, just ran back inside to take a picture of the diagram so I know for sure. Wish me luck. Airbox removed so far.
Polestar is offline
post #104 of 625 (permalink) Old 03-19-2016, 02:59 PM
cspaced's Avatar
Good luck man! I went through the wheel wells. Just find it easier than removing the battery and air box.
SkipW and Duke2015 like this.
cspaced is offline
post #105 of 625 (permalink) Old 03-19-2016, 04:19 PM
Polestar's Avatar
Mission successful!
The past few times I have went through the wheel well, but wanted to give this a try this time, as the wheel wells are annoying with no access panels on the 2015+.
Airbox is a little bit of a pain to remove... but it came out eventually.
Battery is annoying cause the system really doesn't seem to like it being remove from power.
Lights powered on and no errors... Took it for a drive and a wash and can't wait to see the difference at night. Will post pics when I can.
Polestar is offline
post #106 of 625 (permalink) Old 03-19-2016, 07:28 PM
Thank you @XenonDepot for this plug and play 5000K HID kit, and for posting the wiring picture. The lights worked first try with no errors!
Also thank you Pat @ptrudel for the instructions, I would not have known where to start without them. While I was in there I installed the 6000K LED fog lights from Xenon Depot and I'm happy with everything.
I'm annoyed at Jeep for the design, changing a lamp should not require such a big operation. lol
ID:	112770   Click image for larger version
SkipW, ptrudel, Warlin and 1 others like this.
intrepidusa is offline
post #107 of 625 (permalink) Old 03-19-2016, 08:21 PM
imthatguy's Avatar
Here's a night shot. As soon as I get somewhere with a garage/flat surface, I'll show those pics as well.
Very impressed with the amount of light and the throw from the stock housings. No lines that I can see either, so I must have twisted them the right way! So much more distance and spread too. Seeing a lot of things I never would have seen before. I had HID's way back in '07 when I had my Mazda3 and always missed them. Really pleased with the hint of blue from 6k's. All in all, probably the first upgrade anyone should do to their KL. Thanks @XenonDepot!
post #108 of 625 (permalink) Old 03-19-2016, 08:41 PM
Can you give us who have not done the install yet a hint as to what is the 'right way' ;-}
imthatguy likes this.
SkipW is online now
post #109 of 625 (permalink) Old 03-19-2016, 09:02 PM
teo
Is the light blinding for other drivers?
2016 TH
teo is offline
post #110 of 625 (permalink) Old 03-19-2016, 10:06 PM
2016 TH
Absolutely. Compare above pics with a true HID-projector retrofit:
http://imgur.com/a/Q3ojg
flaco is offline
Cherokee Fog Light LED Bulbs! Several Bulb Options! New XML2 Added! Plug and Play!! Diode Dynamics Diode Dynamics 77 Yesterday 09:57 PM
FOR SALE
2014 Jeep Cherokee 55w HID Kit from Retro Solutions
Dundas Cherokee (KL) Parts & Accessories 5 08-07-2016 09:24 PM
2015 Jeep Cherokee HID Kit - No resistors! XenonDepot Electronics, Audio, and Lighting 165 03-11-2016 01:42 AM
FOR SALE
Dundas Cherokee (KL) Parts & Accessories 5 10-14-2014 09:15 PM
resistors for HID(need information) realcaptain Electronics, Audio, and Lighting 11 07-10-2014 07:51 AM
