2014+ Jeep Cherokee HID kit - No Resistors - Plug+Play - Page 2 - 2014+ Jeep Cherokee Forums
 389Likes
post #11 of 625 (permalink) Old 03-10-2016, 10:28 AM
RojStock's Avatar
Originally Posted by Forcevoid View Post
  1. So the selected option should be..."WithoutCANbus"?
  2. What color option (temp) would best match the daytime running lights on my 2014 KL?
  3. How easy are these for a layman to install? Can someone please link instructions/tutorial (if one exists)?
Thanks in advance for answers. My gratitude to you and all the devs and testers for such an easy kit to install and I hope it can work wonders for everyone. The OEM headlights on the KL are a joke and borderline unsafe imo. Hoping to upgrade soon.
I have the same questions for @XenonDepot.
When you go to the page it prefills with the "Without CANbus" option filled in. That too me is different then 'Do not select any option". I assume it means that the correct option we need is already selected but I need that in plain English.
Also does the Philips Bulb 4300K provide more light, last longer, or both of those for the extra $45?
Thanks for all yours and others hard work to get an easier option out there for us.
RojStock is offline
post #12 of 625 (permalink) Old 03-10-2016, 10:55 AM
Steve do we need to order 2 of the new 29.99 MAGIC box kits or are there 2 in the kit if we already have an HID kit from you installed. Thanks in advance. Jeff
osimj is offline
post #13 of 625 (permalink) Old 03-10-2016, 11:57 AM
I have a 2016 Cherokee and bought the 9005 HID Kit with the Mopar 2015+ option. Should I return them and get the same kit without any of the options? Im gonna order the PMW kit module, will it work with the 9005 HID kit w/ Mopar 2015+ option?
Jayhawks22 is offline
post #14 of 625 (permalink) Old 03-10-2016, 02:05 PM Thread Starter
JeepCherokeeClub.com Vendor
XenonDepot's Avatar
@Stabone831 - Thank you for taking the time to respond!!
XenonDepot is offline
post #15 of 625 (permalink) Old 03-10-2016, 02:10 PM Thread Starter
XenonDepot's Avatar
@RojStock - You are correct -- You would need to select "WITHOUT". You honestly would not notice a difference between the XenonDepot bulbs vs Philips. The only actual difference would be that the Philips bulbs color shift to approximately 4700k after 100 hours of use -- which means that the color will get "crisper". Just double-check your bulb type, as we have had some 2016 owners tell us they needed 9005 bulbs -- which are different from 9012..
@osimj - They are sold in pairs! Good point btw, i will add that to the site.
@Jayhawks22 - double check your bulb type ,because a 9005 bulb is different from a 9012 bulb.
Steve
RojStock and CaliEcoGreen like this.
post #16 of 625 (permalink) Old 03-10-2016, 04:30 PM
jeff215267's Avatar
sorry to be a pain in the ass,Just ordered the pwm kit,your website has conflicting info,let me get this straight,2016 here
I can install the 9006 bulbs in place of the hir or 9012,I know its the right bulb cause i have the leds with blue boxes 2 on each side
Do i need to use the relays,blue resistors only pwm?
Install bulbs,no relays,no resistors,just the bulbs,ballasts and the pwm kit,is that correct?
jeff215267 is offline
post #17 of 625 (permalink) Old 03-10-2016, 04:49 PM
If you have 9006's in your 2016, then yes. You will install the bulbs, the ballasts and the PWM kit. That's it.
If you have 9005's, then you'll need different bulbs, the ballasts, and the PWM kit.
post #18 of 625 (permalink) Old 03-10-2016, 06:11 PM
jeff215267's Avatar
thanks gravitywell,I cant wait,are u switching to them too?
post #19 of 625 (permalink) Old 03-11-2016, 08:54 AM Thread Starter
XenonDepot's Avatar
Hi,
You would just need new bulbs and PWM kit -- the ballasts are the same.
Steve
post #20 of 625 (permalink) Old 03-11-2016, 09:13 AM
Wobbie's Avatar
So does the intermittent and brief error exist when ESS is doing its thing?
Wobbie is offline
Cherokee Fog Light LED Bulbs! Several Bulb Options! New XML2 Added! Plug and Play!! Diode Dynamics Diode Dynamics 69 Yesterday 11:54 PM
FOR SALE
2014 Jeep Cherokee 55w HID Kit from Retro Solutions
Dundas Cherokee (KL) Parts & Accessories 5 08-07-2016 09:24 PM
2015 Jeep Cherokee HID Kit - No resistors! XenonDepot Electronics, Audio, and Lighting 165 03-11-2016 01:42 AM
FOR SALE
Dundas Cherokee (KL) Parts & Accessories 5 10-14-2014 09:15 PM
resistors for HID(need information) realcaptain Electronics, Audio, and Lighting 11 07-10-2014 07:51 AM
