XenonDepot HID kit step by step installation guide - Page 2 - 2014+ Jeep Cherokee Forums
 32Likes
post #11 of 120 (permalink) Old 08-03-2016, 12:08 AM
cherokeebill's Avatar
So everything worked out fine except my drivers side headlight goes out. I determined that the connector from the bulb to the PWM module is loose. This is the connector that I reversed the pins on. Has anyone had experience with this connector being loose and if so how did you correct it? I have emailed Xenon Depot and am waiting their reply. I wonder if I need a new connector or should I simply do away with the connector and solder the wires together. Any thoughts?
Again, thanks for the help from you guys.
2015 Cherokee North; 3.2V6, Tow group, cold weather group, 8.4 Uconnect w back up camera, Tuhle racks. Nokian all weather tires. XenonDepot 4300k
cherokeebill is offline
post #12 of 120 (permalink) Old 08-03-2016, 08:38 AM Thread Starter
ptrudel's Avatar
You can try tightening the lock on it. Undo the pins again, and give the lock a bit of a pry outwards. Also use some dielectric grease on your connections.
ptrudel is offline
post #13 of 120 (permalink) Old 08-21-2016, 01:54 PM
Just installed 4300k HID PWM kit in right side in 16' Trailhawk and I'm seeing the large shadow at 4 o'clock or 8 o'clock depending on bulb orientation. Is this normal? Can it be remedied?
dspears0809 is offline
post #14 of 120 (permalink) Old 08-21-2016, 11:38 PM
Yes it can be remedied... rotate the bulb! It can go in a few different ways.
brent is offline
post #15 of 120 (permalink) Old 08-22-2016, 12:57 PM
Just installed my XD kit (4300K Phillips with PWM modules). Thanks to ptrudel for the instructions. A few observations on my install that might help others:
1. As others have reported, I found it easy to access both headlights from the wheel well (with the wheels on). I had the steering wheel turned full right. Just removed the 3 screws holding down the wheel liner and pushing it aside. Strangely, this gave me good access to both sides (i.e. I didn't switch to full left for the passenger side). I didn't need to remove anything and could actually reach down from the engine bay to pull the wires up and adhere the various boxes to the side wall. My experience may not apply to others with larger hands. The whole thing went very quickly. Helps to use one of those cheap, led light headbands.
2. I used the 3/4" forstner bit. Great bit choice, but I think a larger size is needed. I would even go to 1 1/8". While you can disassemble the connector to get through the smaller hole, the grommet I was given was just too big for a 3/4" hole. I ended up with an imperfect hole trying to make it larger, but the grommet is forgiving at covering up any irregularities.
3. If you remember to remove the clear plastic cover from the bulb before doing anything else it's a little easier then having to cut it up.
4. Don't forget to include the big o-ring when you screw the covers back on.
5. I inserted the bulbs with the wire at 6 o'clock as someone suggested and rotated clockwise in place. The passenger side bulb actually went in at something more like 7 or 8 o'clock.
All in all, a great product, easy install (no polarity issues) and pleased with the result.
15 TH Anvil, Tech, C/C, Safety, UConnect 8.4AN. Mods: RAX, Sharkfin Antenna, Android Box, XD HID 4300K, Aussie Lift (HazardSky), BFG KO2 255/70R17
Sully is offline
post #16 of 120 (permalink) Old 08-22-2016, 02:25 PM
First of all, thanks for the excellent procedure!
Some additional comments and questions...
I had the hardest time figuring out where to cleanly mount everything (ballast + PWM module + other black box). Mine looks really messy. Were you happy with your mounting locations? Can you share a picture?
I encountered the same issue. 3/4 is not large enough... the grommet will bind and pinch unless the hole is bigger. I ended up using a utility knife to shave the diameter out to about 1" seemed adequate for the grommet.
Yes, I made this mistake (left the caps on and decided to cut them, which was fine but a bit more messy and unnecessary.)
There's an O-ring? :-O ... I didn't notice; is it something that would normally stay on the cover, or would it have fallen out immediately upon removal? The reason I ask is because I unscrewed it blind from the top. Hopefully, they didn't fall out.
Thank you for this, I couldn't find a position that would eliminate the shadow line. I may have to try again :-(
A couple other thing to note...
- I connected and tested everything and it worked fine.... until I fastened everything into place. The right side stopped working unexpectedly. I inspected all the harness connections and they looked good, but only upon re-seating them did they work. I've read of others with a similar experience, so make sure your connections are firmly seated.
- A check engine light appeared after removing and re-connecting my battery during the procedure. I didn't check the code, but it went away after about 15 miles of driving. I'm guessing it was complaining about some sensor due to battery removal.
Thank You!
post #17 of 120 (permalink) Old 08-22-2016, 02:26 PM
@brent
Thank you! I'll try it again.
post #18 of 120 (permalink) Old 08-22-2016, 07:16 PM
Thanks for this awesome write-up. Just ordered my kit, definitely useful to have this guide in hand!
allleee is offline
post #19 of 120 (permalink) Old 08-24-2016, 11:43 AM Thread Starter
ptrudel's Avatar
For the grommet hole, it's possible that something has changed in the kit. When I did my install, a 3/4" is what made my grommet fit the best.
ptrudel is offline
post #20 of 120 (permalink) Old 08-24-2016, 12:05 PM
Toecutter's Avatar
There's a plastic cover? Mine had foam sleeves. Is there plastic wrap on the bulbs beneath the foam sleeves?
2014 Trail Hawk
Toecutter is offline
2016 XenonDepot HID kit install justforfun Electronics, Audio, and Lighting 189 03-06-2017 03:45 PM
XenonDepot HID kit installation guide ptrudel Electronics, Audio, and Lighting 51 11-06-2016 11:51 AM
HID's turns Night into Day A (nother XenonDepot Kit) White Eagle Hawk Electronics, Audio, and Lighting 11 01-07-2016 10:25 AM
XenonDepot xtreme hid kit starting to fail after 6 months? XtremeModder Electronics, Audio, and Lighting 5 11-22-2015 08:26 PM
