XenonDepot HID kit step by step installation guide - Page 7 - 2014+ Jeep Cherokee Forums
 16Likes
post #61 of 68 (permalink) Old 01-06-2017, 08:29 AM
Originally Posted by jp1seattle View Post
So is for that all 2016's that you don't use the relay wire?
Would imagine so. If you read just above the relay page you will see "9006". Believe the relay only applies to that bulb and maybe other Cherokee models. Would try it without the relay harness, just ensure the PMW is in the harness, that is the small "box" that did not come connected to the bulb harness. I did a dry fit in this configuration and no bulb out or other errors were noted.
Was in the same boat as you with this mod. Thought about outsourcing it in the beginning then once I dove into it with the help of this thread it came right along. The hardest part for me was the removing of the fender lining and that was due to poor lighting and not knowing that the three bolts that need to be removed are right next to the fender lip, near the chip protection plastic. On the passenger side it was hard for me to remove the fog light so I had to go in by removing the airbox. What a chore that is. If you go the airbox route just take your time and peel the onion, getting the 5 airbox cover bolts out is a PITA.
Mojave_DaK is offline
post #62 of 68 (permalink) Old 01-06-2017, 08:35 AM
Originally Posted by ati2ude78 View Post
Installed my HID setup with the PWN bypass a few days ago and they have worked perfect. Awesome product. Much better light. Took me maybe 30 min to install them as I just went through the wheel wells. will be buying some for my fog lights soon.
Where and how did you mount the silver power supplies on your rig? Pics would be great.
Thx.
post #63 of 68 (permalink) Old 01-06-2017, 08:16 PM
Thx.
on the bottom side of the headlight assembly casing is a flat area that the ignitors fit onto and then ziptie them on. I also ziptied the pwn kit to the headlight assembly. I will take pictures as soon as I have a chance.
Mojave_DaK likes this.
ati2ude78 is offline
post #64 of 68 (permalink) Old 01-07-2017, 04:43 PM
Hopefully this pearl will help someone:
To remove the wires from the harness connector before slipping through the cover, remove the capture part of the plug. The capture piece is the plastic piece that is on the wire end of the connector. Once this is off and you use the small screwdriver to release the wires, the wires will slip right out. To remove this part is a simple pinch and pull. 1st connecter, 20 mins, 2nd connector, 3 mins if that! This step was not listed in any instructions and at first it is not obvious to remove this piece of the connector.
Lights are installed, fog and head. Take it out tonight and check out the pattern and hopefully better visibility. Don't know who they hire to put the vehicles together or better yet work on 'em but they must have really, really, really small hands as I had a heck of a time getting my hand onto the back of the driver's side cover.
post #65 of 68 (permalink) Old 01-10-2017, 08:27 PM
Thx.
here is a quick pic from the wheel well after pulling back the liner which is how I got in to mount them instead of taking the air housing and battery out
XenonDepot likes this.
post #66 of 68 (permalink) Old 01-12-2017, 08:34 AM
That is a great place and way. Could barely get one arm up there let alone to do that nice of job. Ended up fishing the components to the top of the engine bay and attaching them to the metal beams that run between the fender and grill supports.
Nice job in the install.
ati2ude78 likes this.
post #67 of 68 (permalink) Old 01-14-2017, 04:14 AM
@Andyoconnor83 ;
Question : I've just noticed in your sig you also have a 2016 Renegade. How do you like the halogens on it ? With the HID kit now on the KL, does it equal or surpass the smaller Jeep's lights ? Thx...
Sorry, didn't have email notifications, so just now seeing this. The HID on her cherokee are definitely a bit brighter than the stock halogens of the Renegade. I upgraded the Renegade to LED headlights, and I believe they are at least as bright, but different temperature so hard to compare.
2016 Jeep Renegade Sport 4x4
2016 Jeep Cherokee Latitude v6
Andyoconnor83 is offline
post #68 of 68 (permalink) Old 01-14-2017, 01:09 PM
No worries on the delay, and thanks for the info.
HIDs being *a bit brighter than the stock halogens of the Renegade* says a lot about those halogens, I think. I know that without a side-by-side showdown we can't compare directly, but the fact is the Cherokee halogens are really bottom of the pack performers... to be polite...
And you are right about a different color making it difficult to compare.
At least they're offering HIDs for most KL trims as of 2017 MY. Should have done that sooner...
goobnav likes this.
XenonDepot HID kit installation guide ptrudel Electronics, Audio, and Lighting 51 11-06-2016 12:51 PM
2016 XenonDepot HID kit install justforfun Electronics, Audio, and Lighting 188 10-17-2016 06:35 PM
HID's turns Night into Day A (nother XenonDepot Kit) White Eagle Hawk Electronics, Audio, and Lighting 11 01-07-2016 11:25 AM
XenonDepot xtreme hid kit starting to fail after 6 months? XtremeModder Electronics, Audio, and Lighting 5 11-22-2015 09:26 PM
