HID installed, now CEL. - 2014+ Jeep Cherokee Forums
  • 1 Post By schira
  • 1 Post By HazzardSky
  • 1 Post By phatgreatwall
  • 2 Post By Steveinmedford
post #1 of 7 (permalink) Old 09-02-2016, 05:50 PM Thread Starter
Steveinmedford's Avatar
Hey all.
I installed the Xenon Depot HID kit today. Not to bad. Some connector issues that were resolved (I hope).
Everything seems fine except my CEL came on. I'm hoping its because I had the battery disconnected for a good while. When I first started the car it told me that "Four Wheel Drive Is Temporarily Unavailable", but that went away. Hoping CEL will go out after some cycles or miles.
Anyone else have this happen after the install? As far as I can tell I've put everything back together right.
2014 Latitude, 2,4 L, 4x4.
Thanks
Steve
Steveinmedford
Latitude 2.4 4x4
Steveinmedford is offline
post #2 of 7 (permalink) Old 09-02-2016, 06:00 PM
schira's Avatar
It should go away after a certain amount of time after you reconnect the battery.
It's either a time or number of starts. I don't remember.
2016 Jeep Cherokee Trailhawk 3.2L Rhino
schira is offline
post #3 of 7 (permalink) Old 09-02-2016, 07:48 PM
HazzardSky's Avatar
Just so. It took a full round trip commute to work and back (40 miles each way) for mine to go away when it came on when I did the trailer wiring install. It doesn't like having the battery disconnected for any more than a few minutes but it goes away after a bit when it realizes everything is fine
2015 Trailhawk
Baltimore, MD
HazzardSky is offline
post #4 of 7 (permalink) Old 09-02-2016, 10:18 PM
Just did my hid install with battery removal method, cel came on, also with parksense lanesense unavailable msg. Took my scanner and cleared the code, btw the code was U code so it was due to battery disconnected. Drove it for about 200 meters and parksense and lanesense came back on
phatgreatwall is offline
post #5 of 7 (permalink) Old 09-03-2016, 09:53 AM Thread Starter
Thanks for the replies. Glad to hear the CEL should clear on its own.
Thanks again.
Steveinmedford
Latitude 2.4 4x4
post #6 of 7 (permalink) Old 09-03-2016, 10:52 AM
LarzyHoneytoast's Avatar
Every time I've added lights or messed with the battery the CEL comes on. I freaked out the first time thinking I messed something up because CEL was on and ESS was "Not available". I have an OBDII tool so now I just clear it. I don't remember the actual code but Torque lite seems to think its an issue with a Mitsubishi rain sensor or something of the like. I'll follow up with the actual code once I get my poor-man's-sPOD installed.
Mods so far:
Aussie Lift (3/8" and 1/2" UHMW) @~ 1.45" lift.
A-Pillar Light/CB Mounts
Auxbeam 4" 18W CREE LED Spot Lights
Firestick 3' and 5' antennas
Midland 75-822 Micro Mobile-Portable CB
Thule Aeroblades
Auxbeam X-series 12" 60W CREE LED Light Bar
RRO winch mount, brush bar, prerunner/skid
Warn M8000-s winch
LarzyHoneytoast is offline
post #7 of 7 (permalink) Old 09-04-2016, 02:52 PM Thread Starter
All
No sooner did I thank you for your replies.... then I went and started the car and......... No More CEL.
goobnav and 007 like this.
Steveinmedford
Latitude 2.4 4x4
2016 Year Model Owners : Who has successfully installed an HID Kit with no issues ? Txmusicman7 Electronics, Audio, and Lighting 2 02-01-2016 05:01 PM
KB 9006 hid headlamp/led fogs 5k kit installed Nad34 Electronics, Audio, and Lighting 159 09-09-2015 05:50 PM
HID headlight installed without hot resistor TonyJJJJ Electronics, Audio, and Lighting 17 06-25-2015 01:13 PM
DDM tuning HID installed pics realcaptain Electronics, Audio, and Lighting 9 10-21-2014 01:51 PM
HID kit installed with failing results Dundas Electronics, Audio, and Lighting 14 02-28-2014 11:16 PM
