may be replacing one key fob battery - 2014+ Jeep Cherokee Forums
 6Likes
post #1 of 20 (permalink) Old 12-29-2016, 03:18 PM Thread Starter
rumrunner's Avatar
the key fob I use all the time seems to be less powerful. meaning I can't always start it from my front door anymore, or even as I walk to the car! while my backup still works just fine. thinking this battery can use replacing. make sense? anyone do it? quick & easy? painful & expensive?
rumrunner is offline
post #2 of 20 (permalink) Old 12-29-2016, 03:45 PM Thread Starter
rumrunner's Avatar
ah yes the olde CR 2032. CVS should have that!
fdegree likes this.
post #3 of 20 (permalink) Old 12-29-2016, 10:13 PM Thread Starter
rumrunner's Avatar
easy peasy. just have to remember to remove the adhesive sticker from the battery! DOH!
007 likes this.
post #4 of 20 (permalink) Old 12-30-2016, 09:30 PM
onefunkar's Avatar
just did both on my 13 optima. nothing to it. think they are all pretty easy nowadays.
onefunkar is offline
post #5 of 20 (permalink) Old 12-30-2016, 09:42 PM
wpgguy's Avatar
Hopefully yours is just the battery. I've noticed both of mine are fairly intermittent. Sometimes it'll work, other times I can stand beside the car and nothing happens (with a new battery in the remote). I can hammer the buttons and eventually it'll start responding again after maybe 10-20 seconds of nothing. I havent bothered taking it in, just chalked it up to be possible interference or maybe the Jeep just doesn't like me.
Black Cherokee Sport 4x4 i4
Current Mileage: 33,000km
wpgguy is offline
post #6 of 20 (permalink) Old 12-31-2016, 05:43 PM
onefunkar's Avatar
thats what my optima was doing. getting intermittant then one time car wouldnt start. new batteries fixed everything.
post #7 of 20 (permalink) Old 01-03-2017, 12:02 AM
jas32's Avatar
My personal experience with Key Fobs for cars with Keyless Entry/Keyless Go (push button and/or remote start) is to expect annual battery replacement. The fob is basically "awake" most of the time and more so when it is near or inside the car. I have not replaced the one on my KL but did it a few times with my previous GC and as others said, replacement is fairly easy.
Instead of being alarmed not being able to open or start the car, I decided to put in a reminder on my calendar to replace the batteries every year, instead of waiting for the batteries to fail.
jas32 is offline
post #8 of 20 (permalink) Old 01-03-2017, 08:42 AM
You do not want to have to replace the FOB! If you do hold on to your wallet.....................
post #9 of 20 (permalink) Old 01-03-2017, 09:31 AM
Prying apart the fob is a bit easier (and won't damage the plastic) if you use a plastic trim tool.
I bought this set from Amazon, it has paid for itself many times over.
https://www.amazon.com/Panel-Removal...val%2Bkit&th=1
mowcowbell is offline
post #10 of 20 (permalink) Old 01-05-2017, 03:59 PM Thread Starter
rumrunner's Avatar
not working again. well, finicky. I can lock or unlock from a distance but not remote start. took it apart & put it back together, then remote start worked but couldn't turn it off from a distance (not that I ever knew how). might try another new battery & might use the other fob as my main one & keep this one as the backup
Key FOB IDbound Interior 6 03-24-2016 02:50 AM
Key fob Smiley1857 2014+ Jeep Cherokee General Discussion 6 01-21-2016 09:19 PM
Fob died? (not battery) RockyMtnHawk 2014+ Jeep Cherokee General Discussion 3 05-02-2015 07:20 PM
Key Fob Jagr71 2014+ Jeep Cherokee General Discussion 20 04-13-2015 07:07 PM
Replacing a Key Fob ronnyber 2014+ Jeep Cherokee General Discussion 19 11-17-2014 07:58 AM
