Cost of dealer fog lights installation? - 2014+ Jeep Cherokee Forums
 4Likes
  • 1 Post By shemmar360
  • 2 Post By SkipW
  • 1 Post By Mark_
post #1 of 8 (permalink) Old 01-11-2017, 06:32 PM Thread Starter
I have 2014 sport and would like to eventually add fog lights to it, has anyone every gotten a quote from a dealership about that installation?
Mileage: 20k+, Bought @ 18K in 2016
Issues: 1 = Ignition Coil went bad, replaced under warranty
Status: Running perfectly
Upgrades:
* Uconnect 8.4 RA4 w/ Nav
* Interior LED foot well lights
shemmar360 is offline
post #2 of 8 (permalink) Old 01-11-2017, 11:10 PM
I know there is at least one member here who did their own fog install on a Sport, I think it was @wpgguy. I don't know that it is a difficult install, but maybe a call to your dealer will get the quickest answer....
post #3 of 8 (permalink) Old 01-20-2017, 09:46 PM Thread Starter
Update: Dealer said theres no mod or option to add fog lights to 2014 sport, if you want a backup camera added though, its gonna be 600 bucks *im sure that can be cut down by $100-$200 if you buy and bring your own parts . i already know that someone here manually added fog lights to their sport but i dont wanna go through the trouble of all that, if anything i'll probably just get the best headlight kit on the market to help with lighting conditions at night.
Mark_ likes this.
Upgrades:
post #4 of 8 (permalink) Old 01-20-2017, 10:18 PM
I can personally recommend the XD HID kit for 2014 KLs. I put the kit in mine and it makes a huge difference in visible light in front of the vehicle.
Mark_ and shemmar360 like this.
post #5 of 8 (permalink) Old 01-21-2017, 08:11 AM
DenGas144's Avatar
I swapped my fogs for the Rigid Industry's... they're legal for driving and I couldn't be happier.
Around the time they arrived I had knee surgery so I had gotten a quote for someone else to install them.. $300 bigs ones. I said no thank you, dealt with a little bit of pain, and put them in myself. Little tricky to get to some of the bolts (I didn't remove the tires) but totally doable.
DenGas144 is offline
post #6 of 8 (permalink) Old 01-21-2017, 10:48 AM
^^^This, 110%. I just installed the HID kit, lowered the factory headlight aim a bit and the result is... I can see now.
Just a note : using fog lights to enhance poor headlights is not only counterproductive (it doesn't help), it is annoying to other drivers and is illegal is some states and other countries. HID kits are not leagal either, but in these halogen projectors, with a correct aim, they are not offending to oncoming drivers.
Good luck
shemmar360 likes this.
post #7 of 8 (permalink) Old 01-21-2017, 03:41 PM
I am really impressed with infinity illumin x led headlights. Super bright and very strong high beams. 10 year warrenty.
ID:	147505   Click image for larger version
delish is offline
post #8 of 8 (permalink) Old 01-24-2017, 10:30 AM
wpgguy's Avatar
Adding foglights can be done for around $100 to make it look stock, the only downside is you will need a switch to turn them on/off, there is currently no way to swap out the current headlight switch for one that has fogs as the vehicle itself isn't programmed for them.
If you have some experience with wiring, dismantling, and a garage, then this is definitely a DIY project, otherwise you might have better luck finding a brighter headlight.
Black Cherokee Sport 4x4 i4
Current Mileage: 56,000km
wpgguy is offline
Fog Lights wpgguy 2014+ Jeep Cherokee General Discussion 16 12-20-2016 12:05 PM
Fog lights AJU72 Electronics, Audio, and Lighting 3 09-17-2016 06:29 PM
Fog Lights Hippogriff 2014+ Jeep Cherokee General Discussion 11 09-29-2015 12:32 PM
LED front lights with fog lights, ILLEGAL? crashncam400 2014+ Jeep Cherokee General Discussion 19 01-21-2015 01:18 AM
