Cruise control - 2014+ Jeep Cherokee Forums
 3Likes
  • 1 Post By Dirty 230
  • 1 Post By David_Baker
post #1 of 6 (permalink) Old 03-19-2017, 11:56 PM Thread Starter
Cruise control
Driving down the road today and my cruise control stopped working.
When I push the cruise button the little icon came on.
When i hit the set button it would turn off.
I tried over and over to set it. No go.
I pulled over disconnected the battery for a minute and got back on the road.
Bingo all systems go.
Array likes this.
Dirty 230 is offline
post #2 of 6 (permalink) Old 03-20-2017, 12:53 AM
My lane departure warning at random times turns off and pressing the button does nothing. Next restart all back to normal. Too many computers...
Array likes this.
post #3 of 6 (permalink) Old 03-20-2017, 07:52 AM
Exclamation
All the more reason for an extended warranty!
post #4 of 6 (permalink) Old 03-20-2017, 08:26 AM
May have nothing to do with your situation but two things can cause this to happen.
* The 2 lane markings (generally requires 2) can not be read for some reason. May look the same but it can not read them. I find it will read the side of the road as a lane marking, even though there is no lane marking. I would guess if the side of the road is distinct enough it it can determine that it considers that a lane marking. Also depending on the paint on the road if it can't read the lane it turns off.
I find mine will turn off but resets by itself after clear lanes are sensed.
* I believe if you counteract the lane adjustment that the steering wheel makes 3x the system turns off. I find that it will eventually reset if those conditions are eliminated.
I find usually our interstate highways have nice wide lanes and the system tends to work better. With narrower lanes it seems to keep me closer to the center line than I am comfortable being.
I tend to to stay a bit further away from the center lane divider than the system likes, thus will turn off as I counteract it.. With our 2 lane roads the system works good except when there is traffic and again I keep further to right of the center lane than the system likes.
I have found sometimes a combination of the two will shut it down, especially my tendency of driving further from that center line than the system approves.
post #5 of 6 (permalink) Old 03-20-2017, 08:53 AM
Basically a forced system reset....................
Not to be critical but disconnecting the battery is not recomended, especially on this Cherokee.
The systems are all computer controlled and depend on constant power.
There are error codes etc that are stored that could be lost.
Many times you can get the same result by turning off the ignition and waiting a minute or two.
When you restart the vehicle you may notice the system does a boot up. That is the various light go on and off in the EVAC to verify the component is working. If not you will get an error message or the light will stay on. Even in the off state stuff is going on which is why battery drain is an issue with newer vehicles.
Glad it worked out for you but its is a gamble each time you do it.
Thanks for sharing.
As a side note FCA's issue with the last recall concerning the data crimping cable for the transmission was basically if it happens, before you get it in, to simply turn off the ignition and restart the vehicle.
Obviously the system just reboots and all is fine.
post #6 of 6 (permalink) Old 03-20-2017, 04:51 PM
Na I get all that, what I mean is the indicator to tell you it's turned on disappears off the dash and the yellow Light on the button comes on to tell you it's disabled. A momentary flash on the dash of Lane Departure system unavailable and that's it. Hit the button and no difference. It can do this while driving or when first starting the vehicle. Whenever it does it it only clears when next restarting vehicle. I should add this is probably 6 times since owning the vehicle over 18 months. I haven't had it happen since the last service where 7 different systems were flashed / updated. Time will tell I guess
Jeepster1 likes this.
Can't see milage b/c cruise control in on?! dbfree 2014+ Jeep Cherokee General Discussion 7 04-17-2015 05:44 PM
Down hill and cruise control... baymnn Engine and Technical Discussion 21 02-13-2015 09:21 PM
Ultimate cruise control Tiefy Electronics, Audio, and Lighting 5 02-05-2015 10:43 AM
Cruise Control Issues? Skyla Engine and Technical Discussion 8 07-16-2014 05:18 PM
Cruise control MarkS49675 Electronics, Audio, and Lighting 5 04-01-2014 08:47 PM
