Why would I have? - Page 3 - 2014+ Jeep Cherokee Forums
 23Likes
post #21 of 27 (permalink) Old 04-04-2017, 01:09 PM
4. If you get this to work, more power to you. Amen, brother. If not, see if you can have the 9-speaker system added to your build sheet.
Isn't that something where even though audio equipment wiring can be accounted for between the radio and battery/ground and amp and speakers, the data lines can put the kibosh to making a change like adding a factory amp. Noticed there are CAN IHS + and - lines going to the factory amp.
What did you mean in your statement I bolded above? Might that reconfigure the CAN IHS bus to get it to work?
Also, would an aftermarket amp be an easier and just as good approach?
post #22 of 27 (permalink) Old 04-04-2017, 02:03 PM
Arrow Complicated Mess!
The way these cars are built today it is no longer easy to install something offered as an Factory option, and try and install it yourself.
1 DRLs: My Journey did not come with these. My Dealer had to find them on the Master List which has all the Options with their designated codes. In order to activate my DRLs, the Tech had to first find the code, and then add the code to my Build Sheet. This process activated my DRLs.
2. These codes come and go off of the Master List. There is no rhyme or reason for this. The Code for DRLs had actually fallen off of the list. When it magically reappeared, I was able to active my DRLs.
3. Auto Headlights. Again, my Journey did not come with them. Doing some research, I discovered that all Journeys are wired for them. All I had to do is replace the sensor in the center of the dash, and install a new light switch with the AUTO setting. By the time I got this done, the code for Auto Headlights had once again mysteriously fallen off of the list. When I traded the Journey for my TH, Auto Headlights still had not been activated. If I put the switch to AUTO, all of the exterior lights would come on and stay on!
4. I am so happy that I do not have to do any of this BS with my loaded TH. There is enough room in spare tire well for an amp + the tire!
5. Yes. He should go the aftermarket approach to install an Amp for a Sub. I did the same thing with my Nitro. I purchased the Factory Sub Enclosure and installed an 8" Kicker Sub, with a remote Bass Controller. The Amp was installed under the rear cargo floor. The spare tire on my Nitro was outside and could be lowered with a cable. The Tech used speaker level inputs from the front speakers to power the Amp; + the wires from the battery.
6. If he wants the Factory Sub to work, he would have to add the 9 Speaker Option to his Build Sheet; doing this is no guarantee that it would work due to CanBus issues. Aftermarket is the only way to go.
Array and NScherry like this.
dhh3 is online now
post #23 of 27 (permalink) Old 04-04-2017, 02:45 PM
@dhh3 - Very enlightening. Thanks.
There are a lot of cool things done through messaging over these buses without needing the cabling of an old fashioned computer room, but like you said, it gets real complicated.
post #24 of 27 (permalink) Old 04-04-2017, 04:53 PM
Yes it does! But it frustrates me to no end not to be able to do the things I want to do. My TH has every option except the CD player, which I really want. With the CD player, the inside of the console is different. And to think I could just buy the CD player and plug it into the radio. What was I thinking?
dhh3 is online now
post #25 of 27 (permalink) Old 04-04-2017, 05:02 PM
What's a Cee Dee?
But, really. When is the last time you had media on a disc? I have my entire library on a flash drive the size of half of a pack of gum (probably smaller.)
Physical media is so 1995
gravitywell is online now
post #26 of 27 (permalink) Old 04-04-2017, 05:48 PM Thread Starter
NScherry's Avatar
I assume in the same way I had to get the dealer to activate my RA3 when I installed it to get all the features to work. Thanks for your input guys!!!
NScherry is offline
post #27 of 27 (permalink) Old 04-05-2017, 11:31 AM
Arrow It Has to Remain on a CD!
Originally Posted by gravitywell View Post
What's a Cee Dee?
My wife was a DJ for 20 years on the local rock station. On the day of her funeral, she had given the station a list of my favorite songs to play. They played them from 1 to 2 that afternoon, with no commercial breaks. I have a copy of that list on a CD. The CD is in my door pocket, so she is always with me. I want the CD player to be able to play the CD whenever I want. Putting it on another media device would not be the same.
BTW, All of my CDs are copied to my iTunes Library on my PC, synced to my iPod. I'm constantly buying music off of the iTunes Store, to stay currant.
NScherry and gravitywell like this.
dhh3 is online now
