Bumper flush LED Light - 2014+ Jeep Cherokee Forums
 4Likes
  • 1 Post By dhh3
  • 2 Post By SkipW
  • 1 Post By SkipW
post #1 of 4 (permalink) Old 04-19-2017, 03:50 PM Thread Starter
Has anyone tried these below?
The light pattern seems square with cut line.
https://www.amazon.com/gp/product/B0...A1BS0EZ9I237AF
TonyJJJJ is offline
post #2 of 4 (permalink) Old 04-19-2017, 09:13 PM
Cool
This English cracks me up!
SUPER BRIGHT 7D LENS - Turn night into day! Super 200% Brighter than other work light. 7D lens improve Light Use Efficiency and makes this light bar super bright. Unique reflector flood cups, help emit wider & more average beam to create ultimate & comfortable visual experience avoiding dark or shadow.
CONVENIENT TO USE - Paper model helps you cut out the shape easily. Once installed, these lights look like an OEM factory upgrade.*Plug this plug and play wiring harness in battery and light then turn on switch, this light bar become more brighter than before.
COOL AND PRACTICAL – More than 50,000 hours working lifetime! The flush mount design provides an elegant appearance which makes your off-road vehicle looks fancy. Our durable aluminum housings feature custom, over-sized heat sinks which keep the temperature down and allow our LED's to run cooler and brighter.
EXCELLENT PERFORMANCE - Our circuitry is designed in-house to be more powerful, be more efficient, and generate less heat. With high quality powder coat finish, an unbreakable, scratch resistant lens and IP68 waterproof rate, this 4 row LED light can withstand harsh condition - High level of waterproof create well environment.
WIDE APPLICATION - This flush led light compatible with all automobiles and devices equipped with a 9 to 30 Volt DC power source. We offer 3 YEARS WARRANTY. Remark:This flush led light has been upgraded, more brighter than before!
It's more brighter than before. Before what? The Great Flood?
PHaTBob72 likes this.
post #3 of 4 (permalink) Old 04-19-2017, 09:43 PM
It's brighter than before you plugged it in and turned it on !!
Renthorin and dhh3 like this.
post #4 of 4 (permalink) Old 04-19-2017, 09:51 PM
I think I would look at some of the other options that might be better defined as to beam and output. While the description is prosaic, it does not (at least that I found) specify flood, spot or otherwise. I do not see where you got the beam pattern information. Unless you do not plan on using these except for offroad, the pattern may blind oncoming drivers.
Flush mount Spot LED for fog light? TonyJJJJ Electronics, Audio, and Lighting 0 11-14-2016 03:10 PM
LED Fog Light Housing (not just an LED bulb) cmc1978 Electronics, Audio, and Lighting 23 11-24-2015 10:25 AM
LED Bumper Mounts xrubicon Exterior 14 04-27-2015 02:00 AM
CREE 40W SPOT ROUND 4*10W LED WORK LIGHT BAR CAR FOG Light Driving Jeep Boat Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 12-07-2014 10:30 AM
