SPOD + switch gang or Rasberry Pi + touch screen - 2014+ Jeep Cherokee Forums
 1Likes
post #1 of 12 (permalink) Old 04-25-2017, 02:00 PM Thread Starter
Alfrik's Avatar
I had been thinking about using a Rasberry Pi to trigger and control the various lights I plan on mounting to Hawkeye. Using it as a bit of a learn to code (or re-learn to code) project, with a touchscreen panel mounted where the SD/USB/12v power cord is.
The advantages of this are all control and power would be routed over a single cable run (or maybe two) if the Pi was mounted in the engine compartment. Disadvantages would be coding issues, how to trigger a safe shutdown of the Pi at power off of the Jeep, and I don't think any screens actually fit that space properly. That is, they are either too small or too large.
The other option was a sPOD, which I believe MFC is selling, alongside a machined switch gang designed to fit into that area and relocate the media and power ports as well. The disadvantage, his behaviour on this forum, and the rather abrasive way he treated some of the community.
I'd rather not support such behaviour unless it's the only option. Does anyone have a line into a similarly machined switch gang or sPOD control?
Alfrik is online now
post #2 of 12 (permalink) Old 04-25-2017, 02:06 PM
Wheyman's Avatar
I used switch pros solution in mine and mounted the head unit in the upper sunglass holder. There is a for wire bundle that tires to the head unit and everything else is in the engine compartment.
Wheyman is offline
post #3 of 12 (permalink) Old 04-25-2017, 02:26 PM
RojStock's Avatar
DZ also used the SPOD mounted in the Sunglasses area if you want to take a look as his pretty detailed write-up here ...
GOBI Stealth Rack Part 2 (Lighting)
RojStock is online now
post #4 of 12 (permalink) Old 04-25-2017, 03:59 PM
wpgguy's Avatar
I went with https://rockerswitchpros.com/, bought a 6 bank switch template and mounted it on the overhead console just in front of the MAP lights. All switches are custom as well so you can do what you want (add your own pictures, labels), my wires pass down the a-pillar behind the side airbag. As far as the Pi goes, that seems a little overkill if you're just controlling lights. I've been working on automating my home for the last 2 years with a combination of arduinos, pi, etc all working together. In the end, is it worth it to have an extra screen just for button for a light? You're turning a simple on/off job into something that needs to be parsed and processed by multiple components all relying on your programming and soldering, more chances of something failing. Just my opinion
Black Cherokee Sport 4x4 i4
Current Mileage: 56,000km
wpgguy is offline
post #5 of 12 (permalink) Old 04-25-2017, 06:54 PM
StealthHawk's Avatar
Have you looked at the sPOD SE? Touch Screen or 8 Switch panel (2 types) talking CAN-Bus over a Cat5 cable. I've got the Touch Screen version.
Granite Crystal 2014 TH 3.2
Mods and Additions:
- 265/65R17 BFG A/T KO2's
- Front Runner 57.5" Rack
- HazzardSky Lift
- RRO Supersliders
- L/R Rear factory fog lights
- Viair 450C w/3 gallon tank
StealthHawk is offline
post #6 of 12 (permalink) Old 04-25-2017, 07:10 PM
i would advise against the switch panel for now until others roll out with it. it is not as machined cut as the website portrays it to be, a good portion of the switch panel is (poorly) cut by hand. it is a bit overpriced for the quality of the product you receive. if someone had a CAD drawing of the switch panel and could get it to someone who can properly machine a panel, that would be an entirely different story and i'm sure it would be very helpful!
IRSmart is online now
post #7 of 12 (permalink) Old 04-25-2017, 10:09 PM Thread Starter
Alfrik's Avatar
Interesting idea, except I use my glasses holder. Glasses go in there! Maybe I'll look at getting the headliner cut to fit a switch bank.
post #8 of 12 (permalink) Old 04-25-2017, 10:37 PM Thread Starter
Alfrik's Avatar
Good to know, thanks.
post #9 of 12 (permalink) Old 05-11-2017, 11:32 AM
schira's Avatar
I actually did this a few months ago, but ran into the shutdown issue which I now have a way to control just haven't been able to get back into the project.
Here is the link Accessories without any physical switches
2016 Jeep Cherokee Trailhawk 3.2L Rhino
schira is offline
post #10 of 12 (permalink) Old 05-13-2017, 08:09 AM Thread Starter
Alfrik's Avatar
Awesome! Thanks. I'm really surprised that the UConnect system isn't a commodity x64 CPU, or Pi. QNX has x64 kernels, and running a commodity CPU would allow rapid prototyping and/or updates to the hardware, OS and UI. Not to mention the ability to hack together a CANBUS controlled light system run directly from the Uconnect. Then there's the cost savings of using fully commoditized hardware.
Then by running on x64 hardware everything could be software defined (radios, etc) and relatively easily ported from one OS to another. Linux, especially, has a much better driver stack and availability than QNX, which needs everything ported or written for the hardware. It wouldn't help those of us with current vehicles, but future cars would benefit.
Touch screen issues mllhy 2014+ Jeep Cherokee General Discussion 2 12-28-2015 06:50 PM
AM Reception Touch Screen Beeps HowlingMad Electronics, Audio, and Lighting 6 09-17-2015 02:28 PM
Touch-Screen Maintenance Max57 Interior 21 12-23-2014 10:34 AM
Touch Screen Beep Volume harleymhs Electronics, Audio, and Lighting 0 05-19-2014 07:31 PM
Touch screen blacks out while driving? Bill 2014+ Jeep Cherokee General Discussion 1 03-04-2014 09:00 PM
