Anyone tried to use a 64GB USB flash drive for music? - 2014+ Jeep Cherokee Forums
 9Likes
post #1 of 19 (permalink) Old 08-04-2014, 10:09 PM Thread Starter
dbfree's Avatar
I've heard 64GB doesn't work for the SD card, but will it work for the USB?
Any successes or failures?
Thanks JCC!
2014 Cherokee Latitude 4x4
Granite Crystal Metallic/Morocco Black
3.2-Liter V6
Comfort/Convenience Group
Dual-Pane Panoramic Sunroof
Uconnect 8.4A
dbfree is offline
post #2 of 19 (permalink) Old 08-04-2014, 10:54 PM
tjarget's Avatar
I formatted a 64 GB card Fat 32 and was successful for about a month, til the music started duplicating on the card. Tried again with a new 32, and music is beginning to duplicate again. Still not sure what's going on. I'll just reformat every few weeks til I figured it out. Haven't tried USB.
2014 Jeep Cherokee Limited 3.2 V6
Black with Black Leather
Navigation, 9 speakers and Luxury Group
tjarget is offline
post #3 of 19 (permalink) Old 08-04-2014, 11:58 PM
jkolker's Avatar
It's not the size, but the format. 64GB SD cards are SDXC format, 32 GB is SDHC. There is a difference in hardware, and the Cherokee reader doesn't appear to read the newer (XC) format. I've had this issue with computer hardware as well.
Reformatting may work, but not sure I would do that....
2014 Cherokee Trailhawk - V6 - Deep Cherry Red - Options - All
Ordered 10/11/13, Received 12/9/13
jkolker is offline
post #4 of 19 (permalink) Old 08-05-2014, 11:04 AM Thread Starter
dbfree's Avatar
Hmmm. I wonder if the 64GB USB and the 32GB USB are the same format. If they are, I assume they could both be used!
Still hoping someone has experience with this before I buy!
3.2-Liter V6
Uconnect 8.4A
dbfree is offline
post #5 of 19 (permalink) Old 08-05-2014, 11:07 AM
jkolker's Avatar
I think the Uconnect system reads FAT32 format, which has a 32GB limit. To go higher the format is usually NTFS
jkolker is offline
post #6 of 19 (permalink) Old 08-05-2014, 01:37 PM
generaltso's Avatar
This was only the case with Windows 2000, but that was a limitation of the OS, not FAT32. As long as you format it with a newer operating system, you can format a 64GB card using FAT32. The differences between SDHC and SDXC are much more likely the culprit.
2014 Jeep Cherokee Limited V6 ADII - built 4/21/14
Granite/Morocco Black - Every option except the block heater
generaltso is offline
post #7 of 19 (permalink) Old 08-05-2014, 05:58 PM
clew's Avatar
FAT32 formatting is required. The upper limit on FAT32 is 32GB due to licensing, you wont get your computer to format correctly it without cartwheels/third party software.
jkolker and dbfree like this.
clew is offline
post #8 of 19 (permalink) Old 08-05-2014, 07:14 PM
@JC
Download Fat32 Formatter, it works on any sized usb/flash drive. I use it to format cards to work in tablets and phones that don't support SDXC. Works perfectly.
http://www.ridgecrop.demon.co.uk/ind...at32format.htm
@JC is offline
post #9 of 19 (permalink) Old 08-05-2014, 07:53 PM
denlem's Avatar
I'm running a 750GB hard drive formatted under FAT32 with no problems.
17,000+ songs on it right now. Forget what the others say. It can be done.
fusseli likes this.
2014 Cherokee Trailhawk - Eco Green
Options: V6 Nav Leather Sunroof Comfort Cold Weather Black Wheels
Build: 05/02/14 - On Lot: 05/12/14 - Mine: 05/16/14
Accident: Rear Ended: 02/25/15 Repair Cost: $4707 Repaired: 03/20/15
Mods: LED Interior and license / 750GB Hard Drive with 16,000+ songs / 6000K SEOUL LED Fog Lights
MIL code U0402: 06/15/15 New Trans: 06/19/15
denlem is offline
post #10 of 19 (permalink) Old 08-05-2014, 08:15 PM
clew's Avatar
No ones saying it can't be done...
clew is offline
After Tranny Flash 21-018-14 Steveinmedford 2014+ Jeep Cherokee General Discussion 11 07-19-2014 12:57 PM
Question about music: album covers for USB/SD dbfree Electronics, Audio, and Lighting 4 07-13-2014 08:56 PM
USB Flash Drive for Music Question dbfree Electronics, Audio, and Lighting 16 07-09-2014 11:33 PM
Is there any difference between music on USB vs. SD? dbfree Electronics, Audio, and Lighting 17 07-09-2014 02:06 AM
New update Flash 21-018-14 rfranchi@comcast.net Engine and Technical Discussion 0 06-09-2014 01:13 PM
