Headlight bulb removal - Page 2 - 2014+ Jeep Cherokee Forums
 7Likes
post #11 of 14 (permalink) Old 10-16-2014, 06:40 PM Thread Starter
B J Douce's Avatar
So I found out yesterday that you can easily pry them out with a screw driver. When you put them back on, line up the tabs on cover with slots in housing, then turn clockwise to secure. Thanks for all the help everyone.
I wonder why they are designed like this, maybe to seal as you can forge water with these Jeeps.
Jack Sparrow and Duke2015 like this.
B J Douce is offline
post #12 of 14 (permalink) Old 02-20-2017, 01:55 PM
2016 jeep cherokee limited.
Need help to access the headlight bulbs on a 2016, and location of adjustment screws on the projector headlights. The dealer wants to charge my $92 dollars to adjust the headlights, that is absolutely ridiculous.
Note: There is no longer a door in the wheel well to access the headlights. Bad design on Chrysler/Jeep for taking that away.
Fj4080 likes this.
Lakedog is offline
post #13 of 14 (permalink) Old 03-15-2017, 09:40 PM
Do you have to remove the airbox? It's kind of cramped
to even grip the cover and turn it
Sent from my SM-T357T using Tapatalk
Lupesman is offline
post #14 of 14 (permalink) Old 03-15-2017, 09:56 PM
Sorry fo rthe late reply, I didn't see your post until now. If you are still waiting on an answer...
Member @David_Baker posted a nice pic of the adjuster screw, just follow next link :
HID conversions - blinding everyone in front of you?
... and I'll throw in a pic of it on the headlamp assembly :
(use a 6mm hex bit (aka Allen wrench))
HI there,
There are two techniques :
1) From behind through the wheelwell : remove 3 screws on the wheelwell adn peel back for headlight access (and fog light access too). You can do this without removing wheels ; just crank steering wheel to one side.
2) From above by removing airbox (passenger side) and battery (driver side).
Good luck...
Fog Lights bulb update jeep4u Owners' Garage 11 08-30-2014 12:11 AM
Reverse light bulb (all 4) mtudb24 Electronics, Audio, and Lighting 2 05-31-2014 12:20 AM
HIDs Installed-Keep gettiing bulb out message Wild Charge Electronics, Audio, and Lighting 5 03-05-2014 11:10 PM
Bulb options for HIR2? JeepRod Electronics, Audio, and Lighting 1 01-12-2014 05:17 PM
exterior lighting bulb types? Dundas Electronics, Audio, and Lighting 1 01-08-2014 10:18 AM
