Headlight bulb removal - 2014+ Jeep Cherokee Forums
 7Likes
post #1 of 14 (permalink) Old 10-10-2014, 08:07 AM Thread Starter
B J Douce's Avatar
Lightbulb Headlight bulb removal
Okay so what is the trick to get the covers off the back of the headlights? Do they unscrew or pry off ?
B J Douce is offline
post #2 of 14 (permalink) Old 10-10-2014, 09:54 AM
Gersh's Avatar
Turn counter clockwise
Gersh is offline
post #3 of 14 (permalink) Old 10-10-2014, 10:26 AM
If you're talking about the cover in the wheel well; turn counterclockwise on the 2014, 2015 remove the wheel well lining.
GCWIMMER is offline
post #4 of 14 (permalink) Old 10-10-2014, 10:41 AM
Jack Sparrow's Avatar
They unscrew like the others stated... be careful when unscrewing those plastic retainer screws because mopar at this time does not sell them individually and it's easy to mess them up if just using a flat head. I used a 1.5 inch putty knife and it worked like a charm and did not mess up the retainers. Some others have used the top edge of a box cutter razor which is almost the same size as the flat head seam on the retainer. Also, it's best to slightly push into screw retainer when turning. Hope that helps.
Silver Trailhawk 2014: 6.4 Hemi, No Decal, Built 5-23-14
Jack Sparrow is offline
post #5 of 14 (permalink) Old 10-10-2014, 12:09 PM Thread Starter
B J Douce's Avatar
Thanks for the help, all. I should have been more specific as I had no problem getting the access door open. What I meant was the round cover behind the headlight. Does that unscrew or pry off. thanks.
Number 5 in the following picture, is behind the bulb, correct ?
post #6 of 14 (permalink) Old 10-10-2014, 12:17 PM Thread Starter
B J Douce's Avatar
Lamps, Front Headlamp - BULB, Headlamp
post #7 of 14 (permalink) Old 10-10-2014, 12:22 PM
zzjdzz's Avatar
zzjdzz is offline
post #8 of 14 (permalink) Old 10-10-2014, 02:51 PM
O|||||||O's Avatar
And don't loose the o-ring seal in the cap. Not much holding it in place.
B J Douce likes this.
Aka "Krug"
2014 Mango Tango TH
Born on 4/14
Yes, it's been perfect so far
O|||||||O is online now
post #9 of 14 (permalink) Old 10-14-2014, 06:10 PM Thread Starter
B J Douce's Avatar
Lightbulb Lightbulb Headlight bulb removal
Wow how tight are those round covers, tried for a little while can't get them to budge, turning counter clockwise. Suggestions ?
post #10 of 14 (permalink) Old 10-14-2014, 07:28 PM
clew's Avatar
They are tight. Mechanics gloves may help with grip/pain, and a bit of a wiggle while turning.
clew is offline
Fog Lights bulb update jeep4u Owners' Garage 11 08-30-2014 12:11 AM
Reverse light bulb (all 4) mtudb24 Electronics, Audio, and Lighting 2 05-31-2014 12:20 AM
HIDs Installed-Keep gettiing bulb out message Wild Charge Electronics, Audio, and Lighting 5 03-05-2014 11:10 PM
Bulb options for HIR2? JeepRod Electronics, Audio, and Lighting 1 01-12-2014 05:17 PM
exterior lighting bulb types? Dundas Electronics, Audio, and Lighting 1 01-08-2014 10:18 AM
