tow hooks on non TH - Page 18 - 2014+ Jeep Cherokee Forums
 114Likes
post #171 of 181 (permalink) Old 07-22-2016, 02:13 PM
EdmontonJeep's Avatar
Cherokke Latitude Tow Hook Brackets and Grille Modification
Originally Posted by Kool1mike View Post
Wow! That looks awesome. I would be very interested in any info on how to do that with my latitude.
Sent from my SM-G935V using Tapatalk
Originally Posted by rski View Post
can you do a write up on how to achieve this.. very interested .. looks bad ass.great job..
I made up some drawings the best I could on how I made the brackets for the tow hooks. I have access to scrap steel plating and welders, cutters, grinders etc. so this was fairly easy for me. It is really important to get them positioned just right so my front bumper had to get installed a few times to get the placement of all the parts just right before welding.
I am typically a purist when it comes to swapping parts so it killed me to use F150 tow hooks but their design made sense for the way I wanted to mount them. The tow hooks are from a 2010 F150. In my fabrication, I made both sides at the same time.
First I had to modify the lower grille by cutting out the outer sections of its honeycomb. there are two ways you can do this. The first is to cut to the first contour which is a lot easier than cutting the honeycomb out only as you will be left with holes where the honeycomb attached. I wanted a deeper inlet so I went with the harder second option. I had to reinforce behind the holes with mesh and used a two part bumper plastic filler to fill any holes. This took many hours as it needed to be sanded many times to get it smooth. I also had the electronic shutter as I have the cold weather package. I had to cut out the openings in the sides of this too.
The first Illustration shows the extension below the bumper on the right side. I removed this and made a new base plate out of thicker steel plate using the old piece as a guide.(Illustration #2)
I then had to make the inside side brace from the same plate steel as the base plate. You will note in the design that there has to be a bend to clear the lines that run in beside this bracket. I used one piece of steel and bent it accordingly to keep its strength.(Illustration #3)
I positioned and welded the inside brace on the back plate to clear the line, while just pressing lightly against the plastic outer radiator shroud.(Illustration #4). Before welding, I installed the bumper to make sure the tow hook was centred in the hole.
I then cut a similar sized piece of square steel tubing as the original extension and welded in the almost identical position of its original piece. The tow hook has to fit snuggly between the square tube and the inner brace. (Illustration #5)
Next, I installed the bumper again to position the tow hook before welding it.(Illustration #6) The whole bracket and tow hook assembly was removed and painted and then reinstalled using grade 9 bolts and washers and the bumper was finally reinstalled for the last time!
The whole project was under $100 in materials but it did take 8 hours over several days which could be an inconvenience if you need your vehicle as your daily driver.
Duke2015 and Kool1mike like this.
EdmontonJeep is offline
post #172 of 181 (permalink) Old 07-25-2016, 11:33 PM
tbrou6229's Avatar
Does anyone know what the actual purpose if this part is? I don't see any place for connecting to this; nor have I seen any pictures showing any use for these...
tbrou6229 is offline
post #173 of 181 (permalink) Old 07-26-2016, 02:09 PM
I don't. If anyone knows it would be interesting. When I installed base plates for towing, both Blue Ox and Roadmaster called them frame extensions, IIRC. Can't imagine what function they might perform. They certainly are not strong.
post #174 of 181 (permalink) Old 07-27-2016, 12:43 AM
tbrou6229's Avatar
No, they are thin aluminum; I doubt they would hold up to much.
post #175 of 181 (permalink) Old 07-27-2016, 01:21 AM
tbrou6229's Avatar
Lightbulb I've got an IDEA!!!
So, if someone came up with a welded steel bracket that bolts to factory mounting points to provide USABLE tow hooks/recovery points on the front of the KL, would anyone be interested???
I've got a design in the works and I'm looking to see if there would be a market on the forum. The total cost will likely be about $225-250 for the entire kit (including hooks).
THIS IS NOT A SALES POST and I don't want to hijack this thread. I just want to see if there is still some interest. I've noticed that this thread has seen a lot of response with some really good research and ideas. I posted this here to *hopefully* catch those with an interest!
I have started another thread for comments. There is also a poll on the other thread. See following link and let me know!
Option for adding Tow Hooks on the KL
Dunx and Duke2015 like this.
~Mods List~ (In Progress!)
The First Family Member...
See HERE for Mod List!
post #176 of 181 (permalink) Old 09-05-2016, 07:45 AM
Originally Posted by madchemist24 View Post
price is high .. I have those parts and with just that, no it will not work.
there is still the ring that goes around the headlight .. then who knows what else is different. I have not pursued this in a while. It gets more discouraging every time I attempt it.
Hi, I still cant put this behind me. Ive read over this thread multiple times in many months. There is nothing I would love more then to swap the ugly front fascia off my limited and swap it with a TH that has recovery hooks. Ive found parts that I could get my hands on.
Apart from the bumper beam, side finders, fascia, tow hooks, it sounds like the only issue is the ring around the headlights? could you possbily explain this a little more I dont quiet understand.
Thank you,
MrLimited is offline
post #177 of 181 (permalink) Old 09-08-2016, 03:35 PM
I'm interested in brackets to mount tow hooks to my 2016 Cherokee Sport Altitude. Have you made any additional brackets and have they worked out ok?
DuaneJBrown1125 is offline
post #178 of 181 (permalink) Old 09-08-2016, 09:14 PM
tbrou6229's Avatar
I'll just drop this off right here...
Add-On Recovery Hooks for NON-TRAILHAWK Models
madchemist24 likes this.
post #179 of 181 (permalink) Old 09-27-2016, 09:02 AM
Jwalbiscut's Avatar
Fabricated my own version this weekend.
madchemist24 and raymorr like this.
2016 Cherokee Limited 4x4 V6
Jwalbiscut is offline
post #180 of 181 (permalink) Old 09-27-2016, 05:25 PM
tbrou6229's Avatar
Those look really good!
Will the V6 really tow 4500lbs Swede Towing and the Towed 65 07-06-2016 09:35 PM
Trailer Tow Group rowkzz 2014+ Jeep Cherokee General Discussion 25 02-14-2014 11:18 PM
Jeep : Grand Cherokee LIMITED LIMITED SUV 5.7L NAV CD 4X4 SteeTow Hooks LEATHER ABS Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 12-30-2013 09:50 PM
Can you add tow hooks to non-THs? R_Willis Wheels, Tires, Brakes, and Suspension 1 12-07-2013 08:03 PM
Access to the front hooks, how? tartagliag Wheels, Tires, Brakes, and Suspension 10 12-02-2013 10:11 PM
