Water Fording - 2014+ Jeep Cherokee Forums
 43Likes
post #1 of 58 (permalink) Old 10-04-2015, 09:29 AM Thread Starter
Water Fording
Okay I did a search for "water" and "depth" and found a few instances of water coming inside the TH. I figured I'd start a dedicated thread to just this.
My personal experience is this. I'm a storm chaser, I've been all over in my TH both old and hope soon the new one. The deepest I've been is water to the headlights without water coming into the TH.
Now, I have seen water splash past the seals in the right rear passenger door but I assumed it was due frame damage or something from bottoming out the TH and twisting something causing the seal to no longer stay sealed.
I know for a fact I have been in water up to the Cherokee logo on the door and didn't have a problem. For those that HAVE had water come in, would that be seen as a failure of the seals and you could make a claim for damage?
Thanks.
post #2 of 58 (permalink) Old 10-04-2015, 09:53 AM
Eugene the Jeep's Avatar
Seems like you want to poke at fire, with a guarantee of not getting burned??
"Wha's a Jeep?"
"The Jeep's a magical dog and can disappear and things."
As his language is limited to the word "jeep,". He possesses high intelligence, so is able to help humans such as Popeye and Olive Oyl solve complex problems. He makes use of a limited form of teleportation: he can disappear from one place and reappear in another, and can walk through and on walls and ceilings. These teleportation powers are said to stem from the Jeep's ability to cross into the fourth dimension.
Eugene the Jeep is offline
post #3 of 58 (permalink) Old 10-04-2015, 09:58 AM
madchemist24's Avatar
Interesting question. I have only crossed water with under 10" depth, but with claims from FCA and photos posted by other, I know I should be able to cross deeper waterways.
Regarding the seal on the rear door .. I am wondering if you saw the "splash" due to the loose fit of the inner weatherseal? I know that mine has been knocked out of place a few times when a passengers exit on the driver's side. I would see it sticking out of the the closed door and have to put it back into its proper location. Seems like a good fit, but occasionally it falls. One time I found the seal laying on the ground under my Jeep. I brought this to my dealer back when having one of the original TSBs done and they said it was an anomaly but would look at it. It stayed in place for a few months before starting to fall again.
So, to your question of failure claim, if I experienced water intrusion in the rear, I would totally be suspicious of that seal and see the failure as a design flaw, until proven otherwise.
Len1304 likes this.
madchemist24 is offline
post #4 of 58 (permalink) Old 10-04-2015, 10:10 AM Thread Starter
My concern is for those such as the current Cherokee of the Month winner who happened to swamp his rig. I'm curious if I could find a statement from Jeep as to how they designed the system. Like Wranglers for example have drain plugs in the floors which would indicate they were designed and expected to get water inside. But I wonder, if the TH was not designed to allow water into the vehicle, then in the case of the COTM winner, would they not be able to make a claim for damage to the vehicle based on the fact that water got past the seals and caused damage or would FCA simply say something along the lines of, you took it too deep or didn't use it as intended.
post #5 of 58 (permalink) Old 10-04-2015, 10:36 AM
.... I'm curious if I could find a statement from Jeep as to how they designed the system. ....
Just because it hasn't yet been said in this thread even though everyone may already know it, Jeep specs the Cherokee's water fording capability at 20 inches.
http://www.jeep.com/en/jeep-capabilities/trail-rated/
GCWIMMER likes this.
post #6 of 58 (permalink) Old 10-04-2015, 10:50 AM Thread Starter
Yes, that's correct that Jeep advertises the Cherokee as able to traverse standing water at 20" at 5MPH. While in the latest owners manual available online it states 9" of flowing water and 19" of standing water but discrepancies are nothing new for Jeep. But what it doesn't advertise or mention is how the water sealing system is designed. Is it by design that the cabin is to stay dry while traversing 19" or as the Jeep homepage says 20" of water. Or like on the Wrangler was it designed for the cabin to get wet but be able to be drained. If it's the first and the cabin was meant to be kept dry, would someone have a valid claim if they traversed no more than the advertised depth and had water come inside the cabin?
post #7 of 58 (permalink) Old 10-04-2015, 10:54 AM Thread Starter
Also, unless I'm incorrect, it's my understanding that ONLY trail rated vehicles get the water sealing properties. While other vehicles don't. And I believe it states in the manuals that if you must cross water to cross water no deeper than the hubs. Which would mean in the case of the Cherokee, only the TrailHawk would be rated at the advertised 20" of water depth.
post #8 of 58 (permalink) Old 10-04-2015, 10:59 AM
To elaborate even more:
4X2 N/A
4X4 ADI 19”
4X4 ADII 19”
4X4 ADII w/drive lock (Trailhawk) 20”
Array, zak0902 and sgrim like this.
GCWIMMER is offline
post #9 of 58 (permalink) Old 10-04-2015, 11:06 AM Thread Starter
4X2 N/A
4X4 ADI 19”
4X4 ADII 19”
I stand corrected, thank you.
post #10 of 58 (permalink) Old 10-04-2015, 12:25 PM
Kevin@kamloops's Avatar
The extra inch is probably to do with the TH extra ground clearance , Nothing to do with fancy seals .
Kevin@kamloops is offline
Water spots sitlet Washing & Detailing 13 10-26-2015 10:49 AM
Water spots? Treaty Washing & Detailing 8 12-11-2014 11:01 PM
The Water Spots Fishsticks Washing & Detailing 13 09-18-2014 07:56 PM
Going through water. How deep can you go in a TH? Timbonz Off-Road 6 06-26-2014 08:52 PM
New water pump hdjoe88 Engine and Technical Discussion 9 05-03-2014 04:27 PM
