Firefox users with Adblock? - Page 5 - 2014+ Jeep Cherokee Forums
post #41 of 53 (permalink) Old 05-15-2017, 02:33 PM
Originally Posted by Alfrik View Post
The "update" to the site is making it nearly unusable on an iPad, and the URL mentioned to whitelist no longer shows up on uBlock Origin as a third party site.
Originally Posted by VS-Admin View Post
.... These were not updates to the site that were made, so we have nothing to roll back on. The scripts being blocked are indeed trackers, so it makes sense that the programs have 'caught' them in their latest updates. Unfortunately, the things these scripts track are what make the site usable for you - they keep track of where you've posted, what you read, if you are signed in or not, etc.
These are not the ad scripts. You can keep the rest of the items listed blocked. It's just the Verticalscope scripts that need to run.
FIXED for uBlock Origin (uBO)
What I suggested in post #38 works. It allows the Verticalscope scripts to run and do their thing, and then uBO can be turned back on to block ads. But it is an additional several steps that aren't necessary.
I did not want to spend time learning more about uBO, but I did after Dayle in post #39 mentioned the Verticalscope scripts need to run otherwise certain functionalities of the site are broken.
Here's why putting 'verticalscope.com' in uBO's whitelist pane doesn't work. From uBO's wiki: "uBO will try to match the URL of the page in the address bar against the existing whitelist directives. When there is a match, uBO will be disabled for that page." Verticalscope.com is a domain and does not appear in the address bar, therefore a match never occurs.
Here are the steps to take in uBlock Origin that uses dynamic filtering to enable the scripts at the Verticalscope domain to run, but still blocks the ads. I'm doing this in Chrome, so navigation may be different in other browsers, but the concept is the same.
1) Right click the uBO icon at the top right of the browser.
2) Click the Options selection in the drop down menu.
3) Select the Settings tab in the new browser tab that opens.
4) Click the checkbox next to I am an advanced user
5) Open a new tab and go to the JCC site.
6) Left click the uBO icon at the top right of the browser and scroll down to the Verticalscope.com entry.
7) In the 3rd column (local dynamic filtering), left click in the left part of that column to turn it Green. The 2nd column is global; don't use that.
8) Click the padlock image to lock it in.
Now you can go to the JCC site, leave uBO on, and the JCC site works the way it used to when the member signed in.
Details: https://github.com/gorhill/uBlock/wi...g:-quick-guide
post #42 of 53 (permalink) Old 05-15-2017, 06:30 PM
Alfrik's Avatar
I'll test some tonight. I'm knee deep in recovering the office from a UPS failure.
Alfrik is offline
post #43 of 53 (permalink) Old 05-15-2017, 09:57 PM
Alfrik's Avatar
Nope, I've whitelisted verticalscope on 1Blocker, and the site still isn't working on iOS.
Alfrik is offline
post #44 of 53 (permalink) Old 05-15-2017, 10:04 PM
Alfrik's Avatar
Okay, white listing the entire site under 1Blocker, I'll get feed back into this attempt.
EDIT: the above was done using the quick post option. Whitelisting the entire site seems to work.
Alfrik is offline
post #45 of 53 (permalink) Old 05-15-2017, 10:08 PM
Alfrik's Avatar
Sadly, whitelisting the entire site brings back the unruly advertising.
Alfrik is offline
post #46 of 53 (permalink) Old 05-16-2017, 12:53 PM
Administrator
VS-Admin's Avatar
Hey there
It wouldn't be the entire site that needs to be whitelisted, just the Verticalscope.com scripts. Try adding static.verticalscope.com and comet-admin.verticalscope.com instead of all of JCC.com.
Dayle
Test
VS-Admin is offline
post #47 of 53 (permalink) Old 05-25-2017, 08:44 AM
Alfrik's Avatar
Hey there
Dayle
Nope. Added just those two sites to 1Blocker on iOS and the site is broken again. No inline images, quick reply doesn't work, and the editing/formatting tools are missing.
Alfrik is offline
post #48 of 53 (permalink) Old 05-26-2017, 09:13 AM
Administrator
VS-Admin's Avatar
Hey Alfrik and others using Ublock,
We recently found out that adding static.verticalscope.com and comet-admin.verticalscope.com didn't pan out in the way we hoped it would. Luckily, we found another way. Try the following steps:
1.  Go to ublock’s dashboard
2.  Go to My Rules Tab
3.  Under temporary rules click edit
4.  At the top of the list put in * verticalscope.com * allow
a.  This is complete with the * and spaces between
5.  Hit save
6.  Hit commit
7.  Refresh the site
Let us know how that works out for you - thank you for your patience and understanding on this.
Cheers,
Natalie
Test
VS-Admin is offline
post #49 of 53 (permalink) Old 05-26-2017, 09:46 AM
Alfrik's Avatar
5.  Hit save
6.  Hit commit
7.  Refresh the site
Cheers,
Natalie
I'll try ublock when I have the chance. However it appears whitelisting the entire verticalscope domain under 1Blocker does nothing to fix the issue.
Alfrik is offline
post #50 of 53 (permalink) Old 05-26-2017, 09:51 AM
Alfrik's Avatar
Testing - so far it still appears the whitelisting of verticalscope on 1Blocker does not fix the issue. Next step is to disable 1Blocker and see if it's an issue with how safari on IOS is handling the site.
Edit: nope, quick reply and the editing/formatting features are still broken after whitelisting the verticalscope domain and a reboot of the iPad.
Alfrik is offline
Calling all LED Headlight Users R2D2 Electronics, Audio, and Lighting 2 03-15-2017 06:15 PM
Uconnect 8 question for EU users Amon Europe 2 07-20-2015 04:31 PM
Help from aFe Intake Users nate Engine and Technical Discussion 13 07-03-2015 10:50 PM
