Firefox users with Adblock? - Page 6 - 2014+ Jeep Cherokee Forums
 4Likes
post #51 of 59 (permalink) Old 05-26-2017, 09:53 AM
Alfrik's Avatar
Turning off 1Blocker in its entirety restores functions missing, as does whitelisting the entire site. That, however, returns the unruly advertising.
Alfrik is offline
post #52 of 59 (permalink) Old 05-26-2017, 04:44 PM
Administrator
VS-Admin's Avatar
Does ublock work? That would be the fastest fix as I don't know of a work around for 1Blocker yet. I'll check around
Kevin
Test
VS-Admin is offline
post #53 of 59 (permalink) Old 05-26-2017, 10:09 PM
Kevin
As stated in post #41, there is a solution using uBlock Origin. This site went from horribly unusable to perfect; the way it was before all the commotion.
BTW, when 3rd Party Scripts are disallowed, the verticalscope scripts do not run and the site is broken. Are these scripts coming in as 3rd party instead of 1st party?
Array is online now
post #54 of 59 (permalink) Old 05-30-2017, 09:20 PM
UN4GTBL's Avatar
FIXED for uBlock Origin (uBO)
What I suggested in post #38 works. It allows the Verticalscope scripts to run and do their thing, and then uBO can be turned back on to block ads. But it is an additional several steps that aren't necessary.
I did not want to spend time learning more about uBO, but I did after Dayle in post #39 mentioned the Verticalscope scripts need to run otherwise certain functionalities of the site are broken.
Here's why putting 'verticalscope.com' in uBO's whitelist pane doesn't work. From uBO's wiki: "uBO will try to match the URL of the page in the address bar against the existing whitelist directives. When there is a match, uBO will be disabled for that page." Verticalscope.com is a domain and does not appear in the address bar, therefore a match never occurs.
Here are the steps to take in uBlock Origin that uses dynamic filtering to enable the scripts at the Verticalscope domain to run, but still blocks the ads. I'm doing this in Chrome, so navigation may be different in other browsers, but the concept is the same.
1) Right click the uBO icon at the top right of the browser.
2) Click the Options selection in the drop down menu.
3) Select the Settings tab in the new browser tab that opens.
4) Click the checkbox next to I am an advanced user
5) Open a new tab and go to the JCC site.
6) Left click the uBO icon at the top right of the browser and scroll down to the Verticalscope.com entry.
7) In the 3rd column (local dynamic filtering), left click in the left part of that column to turn it Green. The 2nd column is global; don't use that.
8) Click the padlock image to lock it in.
Now you can go to the JCC site, leave uBO on, and the JCC site works the way it used to when the member signed in.
Details: https://github.com/gorhill/uBlock/wi...g:-quick-guide
This seems to work for me!
Array likes this.
UN4GTBL is offline
post #55 of 59 (permalink) Old 05-31-2017, 10:15 AM
Administrator
VS-Admin's Avatar
Glad you were able to get it working, is anyone else still having trouble?
Test
VS-Admin is offline
post #56 of 59 (permalink) Old 05-31-2017, 01:26 PM
Alfrik's Avatar
Yes, as described the site is still broken on iOS/Safari unless you whitelist the Jeepcherokeeclub.com domain. White listing the verticalscope domains does not restore functionality.
Alfrik is offline
post #57 of 59 (permalink) Old 06-01-2017, 10:17 AM
Administrator
VS-Admin's Avatar
Still using 1blocker? I've done testing with ublock with my iphone and I'm getting it to work ok. Still trying to figure out exactly why 1blocker is still giving issues
Kevin
Test
VS-Admin is offline
post #58 of 59 (permalink) Old 06-04-2017, 09:22 AM
Alfrik's Avatar
Kevin
Interesting, I see no version of either uBlock or uBlock Origin for iOS listed in the app store.
Alfrik is offline
post #59 of 59 (permalink) Old 06-07-2017, 02:13 PM
Administrator
VS-Admin's Avatar
I think Kevin might have tested using a different ad blocker (they all look the same). Have you tried downloading a different adblocker and deleting 1blocker?
Niall
Test
VS-Admin is offline
Calling all LED Headlight Users R2D2 Electronics, Audio, and Lighting 2 03-15-2017 06:15 PM
Uconnect 8 question for EU users Amon Europe 2 07-20-2015 04:31 PM
Help from aFe Intake Users nate Engine and Technical Discussion 13 07-03-2015 10:50 PM
